| Paulporsche |
11-24-2008 06:07 AM |
my1st911,
My tires are 205/50 so they are approx 3/4" narrower than yours. Your tires are also about 3/8" taller. That, coupled w/ the characteristics of the particular brand of tire, may be enough to cause the rub.
Your ride height seems more than sufficient to me to allow for clearance, though. In fact, from the pic, it looks like the center of the arch is at least 1 1/2" above the tire. I'm wondering if there is another issure here, like worn shocks or worn rear suspension bushings, which are allowing the body to fall onto the tire under load.
OregonCab,
W/ 7s and the same sized tires all around I think the rear track may be SLIGHTLY smaller. Whether this is problematic, I think, may be down to driving habits and car usage. The LOOK would be greatly improved by using the spacers to fill out the arches. Most likely a wider rear track would allow less oversteer and/or improve turnin.
Aircooled911 has what I felt was the max dia for 16x7s on mid years; namely 205/55. I wanted to go slightly smaller (50) so I could go lower w/o issues.
Ossiblue,
As I wrote, I think that is the case re flare sizes. If someone knows this is incorrect, please let us know so w get this right.
Remember, what I did is what I feel is a good aesthetic approach, especially for the type and location of driving I'm doing. If you are tracking the car you may want to explore other options, such as wider rear wheels, larger rear tires, welding on wider flares, etc. As KTL points out, SCs and Carreras already have wider flares, and can accommodate 8s on the rear, although the original post by mnmasauto referred to 7s on an earlier car.
