83 911 Production Cab #10
![]() ![]() ![]() Anyway here we go... PMO EFI Conversion For Dummy (101)
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Finally...
Months behind schedule, too many project on the go and years of Honey Do list back log...
Thanks to Trog (Pelican) and Richard (Clewett Engineering) for their support. I still plan to post all the step by step from the engine drop to the start up (on the second cranking). ![]()
UnRegistered User
Looks great, JJ!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Fantastic !!
Wow jj i am about 1 month behind you. Waiting for r clewett to upgrade my tech unit to twin plug... Then its onti that part i am hoping it starts up in 2 cranks also... Llook forward to your play by play thread cheers frank
Frank
If you have not done it yet (I waited until yesterday ![]() ![]() ), download the software and get the DB 9 to USB cable if require, had to go in 5 stores before I found one at twice the price of the one on line.After doing all the connectors, I did a continuity check from every pins to the main plug. You can check all your power and its sequence while waiting to get your unit back. C.E. 17 steps Tuning Procedure for the 1st start up is right on. Only decided last week where where to mount the unit. It will disappeared under a canvas cover. Now that its working, time to clean up this mess...
Looks great, nice thread. Keep us posted.
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
Look like I will spend my vacation in Tuningville...
Are you still using/happy with the set-up posted at # 229? Did you up-grade your software to version 4.9.26? Thanks JJ
Finally after finding all kind of excuses not to... I did four test run, with different TOG and IOT setting, on Monday. Haven't driven the car since last November, it did feel great and a bit peppier.
The recording shows that the AFR was good on three of the runs. The air intake noise from the engine is totally different to the point that I was starting to question if there was something wrong with the engine. So the car is drivable as is and will be tune overtime... I spend some time on the Electromotive Site and the Tec/GT forum has 269 posts. Most of the question are answer by Jon (from EMI). I plan to read all of them in order to gain some insight. There doesn't seem to have the kind of interaction that we have here on PP. One of the forum is a place for people to post there bin... Well I guess its something that people don't want to share as there is only 11 posts and half of them have no bin. Its not like someone would use them as is but it would be interesting to look at them to see the interaction between the tables. I'll send mine to Jon for advise. I plan to go to a show on Sunday a couple of hours away, it should give the confidence that I previously had as she had never let me down before.
Trog... heard your name murmured with great respect in NASA's camp. Word is... your the one to design & build the engine to get humanity to the next galaxy > > > > >
... and you take damm good photos to boot!
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Anybody got a couple of Filter Base Plate for sale?
No longer required...
I got t whole assy coming @ $123 ea. which is not bad when you factor that the filter are $40 ea.
The new look, photo from the garage.
Tony
Trog - is that backdated filter housing that you used on top of your ITBs the same one for a 67-73 MFI engine? It looks a lot like it. Where did you get it?
That is exactly the look I would like for my engine ... Amazing!
Tony 22 GT4 04 E46 M3 87 Carrera (sold - craving aircooled again) 12 991 Carrera (sold) |
Post #?
Here you go... Quote:
Tony
Absolutely amazing - that has now taken the place of a 3.6l swap on my wish list. Didn't know you could combine the look of MFI with EFI ITBs. Perfect!
New Look (again)... And final one.
Borrowing the idea, of being able to "monitor any signal" from Trog, here is the result of my procrastinating almost finished winter project...
Started on the second try, after plugging the 12 volts to the DFUs ![]() :roll eyes:![]() ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 05-08-2014 at 08:37 AM.. |
Now get yourself a hood shock, or a nicer looking stick. ;-)
Todd
'81 SC |
Got them 3 years ago...
I did use "procrastinating" in the post
