-   -   My PMO ITB Project (http://forums.pelicanparts.com/porsche-911-technical-forum/427451-my-pmo-itb-project.html)
Geneman 05-07-2014 07:48 PM
wow wow jj you da man that is friggin gorgeous!!! congratulations!! it looks specatcular. btw the wiring is way nerdy man are you ocd or what :):) there are drugs for that you know!! i love it.. here is mine just so you see i do not suffer from that syndrome..whatever it is...
mine started also btw...cheers
http://forums.pelicanparts.com/uploa...1399517295.jpg
JJ 911SC 05-08-2014 04:39 AM
Originally Posted by Geneman (Post 8053919)
... are you ocd or what :):) there are drugs for that you know!!...
I tough that that was a precondition for owning an Air Cool :D:):D
JJ 911SC 05-25-2014 08:18 PM
Originally Posted by toddu (Post 8053859)
Now get yourself a hood shock, or a nicer looking stick. ;-)
Todd
Did...
The weight saving is 14.5 oz (2 shocks, bolt, washers, spacer and nut vice the aluminum tube in grandprixweiss) which should give me a ".05mph @ 6500 rpm, down hill with a tail wind" advantage :D
http://forums.pelicanparts.com/uploa...1401073777.jpg
Litle brother 07-20-2014 08:45 AM
Filter lid's
Hi Trog.
Where din You buy the "Racing-Flat-Lids" and what was Your experience with those instead of the rain shields ?
Regards
Eskild.
"I'm using the PMO K&N filters that compliment their ITB's. The exception being that rather that using the rain-shields that were included, I opted to purchase their "Racing-Flat-Lids". The only issue with fitment is sourcing wing-nuts that fit the 12-24 threads on the mounting studs. Looked everywhere, but nobody around here seems to carry them in that size. In the end, I purchased stainless wing-nuts with a 8-32 thread, drilled them out, and re-tapped them to 12-24. Broke 3-taps...damn! "
Trog 07-20-2014 12:15 PM
Hello Eskild,
I purchased the flat lids from Clewett Engineering:
Clewett Engineering, The complete solution for ignition & fuel injection
There was no noticeable change in performance.
JJ 911SC 07-20-2014 05:10 PM
Originally Posted by Trog (Post 8173317)
Hello Eskild,...
Same for my top filter with the half tea ball.
Its more for the look which most really like to see the Air Trumpet.
Litle brother 07-21-2014 11:19 AM
My PMO ITB Project
Thanks for Your fast reply Trog and JJ
Sent from my iPhone using Tapatalk :-)
Frank Hanrahan 10-26-2015 11:49 AM
Does anyone have the Bosch or Porsche part number for the camshaft position sensor?
Litle brother 10-26-2015 01:33 PM
My PMO ITB Project
Hi Frank.
If it's Bosch or Porsche I don't know, but here's what I use: for my ITB setup fro PMO and Electromotive.
http://www.clewett.com/index.php?main_page=product_info&cPath=5_30&produc ts_id=74
Regards
Eskild
davec 10-26-2015 01:52 PM
conversions
I did these conversions a few years back and used Richard Clewett to source all of the components. I also relied heavily on him for advice and moral support, lol. Richard's best advice: "Put it all together, try to start it up and shut it off right away. Fix the gas leaks and try and start it again". LMAO still because you know he was right.
