-   -   My PMO ITB Project (http://forums.pelicanparts.com/porsche-911-technical-forum/427451-my-pmo-itb-project.html)
Trog 08-28-2008 08:03 AM
My PMO ITB Project
I guess it's time I started a thread on my latest upgrade. Having owned my 911 for about 1 - 1/2 years now (actually, it owns me), I've made some significant alterations to its configuration. Some have been positive, others less so. So, after tinkering for the last year, I'm pleased to report that the car runs perfectly. The gearbox has been rebuilt, and is smooth like silk. The MAF is all tuned up, and the engine revs like a banshee.
As I can't leave well enough alone, I decided what I needed was an ITB set-up. So over the next couple of months, this is going to be my new project. Stay tuned (excuse the pun).
http://forums.pelicanparts.com/uploa...1219935727.jpg
http://forums.pelicanparts.com/uploa...1219935746.jpg
Bobboloo 08-28-2008 08:47 AM
Great! I see they give you a piece to join vacuum off each intake to feed a MAF sensor. Looking forward to see how this goes for you.
What engine management will you be using?
dfink 08-28-2008 09:46 AM
I will be following this thread closely as I will doing the same PMO ITB setup soon.
GH85Carrera 08-28-2008 09:52 AM
I presume ITB is Individual Throttle Body?
GaryR 08-28-2008 09:58 AM
What injectors and control system do you use with those? I assume it won't be the stock one...
Trog 08-28-2008 10:00 AM
For those who asked:
I am using the TEC-GT engine management system.
Jeff Alton 08-28-2008 10:32 AM
MAP not MAF....
For a mostly stock motor, the stock injectors will work fine. IF one needs larger I have had good luck with the new Accel bosch style injectors.
Trog, is there a way to adjust/balance the throttle relative to each other? Not just bank to bank, but throttle to throttle.....
Cheers
Trog 08-28-2008 11:17 AM
Originally Posted by Jeff Alton (Post 4145550)
MAP not MAF....
Cheers
I'll be using 26#/hr injectors.
Jeff, see the image below. There's an adjustment screw on each venturi.
http://forums.pelicanparts.com/uploa...1219947384.jpg
Bobboloo 08-28-2008 11:47 AM
Right. I meant MAP. I'm always switching those initialisms for some reason. :)
MAP not MAF....
Cheers
Jeff Alton 08-28-2008 12:35 PM
Good to know about the adjustment screws.
Trog 08-28-2008 01:10 PM
I believe these to be needle valves that allow air to bypass the butterfly valve in a tunable manner.
Now, where can I get a 6-channel manometer?
TimT 08-28-2008 01:22 PM
You don't need to see all six barrels at once when you balance the throats.
Use a "unisyn" and get the airflow on one bank balanced by adjusting the by-pass needles, then balance the other bank, then adjust the airflow of each bank relative to each other so they are balanced.
With ITBs when there is no idle stepper motor or control, you set the idle speed by adjusting the air by-pass or butterfly opening of the throttle bodies. Setting a target rpm in the EFI set up really doesn't do much.
Trog 08-31-2008 07:32 PM
Progress Report
Despite the sunny day, I figured I better get started with the ITB installation. First thing to do is read everything that comes with the kit. That includes the TEC-GT installation and software manual and wiring diagrams. Then take inventory. I quickly realized I was missing the injector connectors and cam-sensor gasket. A quick call to Richard Clewett took care of the missing items. BTW, Richard is a great guy to work with and help is only a phone call away.
The photo below pretty much includes everything you’ll need to complete the installation. Not shown are the fuel lines that I have yet to sort out. I plan to install the TEC-GT under the drivers seat in place of the Motronic. The TEC-GT can be run in open or closed loop and it accepts a 0-5volt Wide Band O2 signal. So to support that feature, I purchased a TechEdge 2J1 Wideband unit:
http://wbo2.com/2j/default.htm
TechEdge is a great company and the parts only took 2-weeks to arrive from Australia. I purchased the optional AFR LCD display that will eventually find its way onto my dash. In any case, the wide-band O2 will come in very handy when it comes time to tune the TEC-GT.
ITB components:
http://forums.pelicanparts.com/uploa...1220235699.jpg
The first item that I installed was the ambient air sensor. Although it’s recommended that you drill a ¾” hole between the #5 and 6 intake in the air filter base for the grommet, I’m pretty sure there will be times that I’ll run without the air filters. So, I made up a bracket and mounted the sensor just below the air filter base. The sensor protrudes into the air filter area so the TEC-GT will receive representative air temperature signals.
http://forums.pelicanparts.com/uploa...1220235771.jpg
The second task was installing the Throttle Position Sensor (TPS). Unlike the On-Off switch that the Motronic uses, the TEC-GT needs an analog signal proportional to the throttle position. The TPS that comes with the kit is a Delco unit. It’s pretty flimsy, so be careful when installing the unit. If it wont turn freely, you have the dowel pin installed upside down. My heavy handedness cost me a TPS as I forced it and broke the internals. The replacement was in stock at NAPA and only costs about $40.00. One area of concern is the TPS resistance. The TEC-GT calls for a 0– 10000 ohm unit. The Delco supplied is only 0 – 5000 ohms. I may have an impedance mismatch problem to sort out. I plan to run a test to see if it will work.
http://forums.pelicanparts.com/uploa...1220235881.jpg
The next task was to install the new crank pulley with magnetic sensor. I suppose if I was clever, I could figure out a way to use the existing flywheel sensor. However seeing that I’m not, I figured that I would use the new Clewett crank pulley. Plus the Clewett pulley is a really nice part; it would be shame not to install it. If you’ve never removed the crank pulley, do yourself a favour and buy one of these:
http://forums.pelicanparts.com/uploa...1220235934.jpg
Removing the crank pulley with the engine in the car requires the removal of the engine mount. So, you’ll need to support the weight of the engine before you remove the support bolts. A few passes of the chop-saw and voila, instant engine support. In order to prevent the crank from rotating backwards as you unbolt the crack pulley, make sure to have the gearbox in 5th gear, and the handbrake fully deployed. One of the engine mount support bolts is really hard to get to (top passenger side). You’ll need an offset wrench to reach it. If others here have a better idea, please feel free to share your experience getting this bolt out. You’ll have to remove your muffler, rear tin, and perhaps the shroud between the muffler and the bumper in order to get your impact hammer in there. If you have an air operated impact hammer, you probably wont have to remove the shroud
http://forums.pelicanparts.com/uploa...1220236032.jpg
At first I thought that I had the wrong Clewett pulley. It’s a really tight fit. So tight, that the magnetic teeth actually touch my fan housing. I had to file about 1-2 mm off the back my fan housing just to feel comfortable with the installation. Richard Clewett tells me that 1 in 30 may have to remove some material. I guess it all depends on the fan housing casting.
http://forums.pelicanparts.com/uploa...1220236082.jpg
Well, that will have to do for today. Estimate about 6-hours to complete the pulley installation and restore the exhaust and rear tin. Unless of course, you have to drive all around town to find the right wrench, then it’s 8-hours.
Tomorrow, I plan to load the TEC-GT software and bench test all the new sensors.
I’m pooped-out now and this Canadian beer I’m drinking is going right to my head.
Stay tuned.
Edited on the 3rd Oct 2008:
WARNING, if you’ve made it this far, skip on down to Progress Report #7. You can thank me later.
Facey 08-31-2008 08:34 PM
nice project! excellent self-documentation. Keep it going?
any chance you base lined the car prior to this? would be interesting
CruiseControl 08-31-2008 11:17 PM
Subscribed
Trog: Looking forward to following your progress and may be able to assist with issues that arise.
http://forums.pelicanparts.com/uploa...1220249621.jpg
Paul
Trog 09-02-2008 08:43 PM
Originally Posted by CruiseControl (Post 4152064)
Subscribed
Paul
Thanks Paul, I'm sure to have many questions for you.
Trog 09-02-2008 08:49 PM
Progress Report #2
Prior to installing the ITB components into the Porsche, I decided that it was prudent to bench test the software and all the various sensors and signals. So I created a test file, and downloaded it to the TECgt engine management system. I wired-up the various sensors to the TECgt and verified that each signal was being recognized by the software. Although the TECgt specified a 10,000ohm TPS, it seemed my 5000ohm unit worked fine. I recorded a throttle-closed reading of .9volts, and a 100% open reading of 4.5 volts. Plenty of range for programming purposes. The manifold air temperature (MAT) sensor worked fine, as did the MAP (Manifold Air Pressure).
The only signal that I couldn’t get to work was the O2 sensor. I tried configuring the TECgt for a wideband input signal (0-5 volts) and narrowband (0-1 volt). I even tried a 1.5 volt battery. Regardless of the voltage, the software failed to recognize the signal input. I contacted Electromotive who were able to resolve the problem. It would appear that the TECgt ignores the O2 signal voltage until it sees the engine running for a specified period of time. I’m guessing that’s to give the O2 sensor time to warm up. I believe our Motronic performs a similar function, however it monitors the cylinder head temperature input. Once it sees the engine has warmed somewhat, it enables the O2 closed loop function. Time or temperature, I guess the effect is pretty much the same. The TECgt software allows the user to program the time delay. However I feel that monitoring engine temperature before entering into closed loop control is a superior solution. I’ll have to do some research to see if the TECgt can be configured to do the same thing.
Here are a few pics of the bench tests:
http://forums.pelicanparts.com/uploa...1220413497.jpg
http://forums.pelicanparts.com/uploa...1220413532.jpg
http://forums.pelicanparts.com/uploa...1220413569.jpg
I’m away on business for the next little while, so my next progress report will be delayed.
Walko 09-03-2008 02:20 AM
interesting project
matty74 09-03-2008 03:29 AM
subscribed
onboost 09-03-2008 07:18 AM
subscribed.. more, more!!
jkh2cpu 09-03-2008 07:34 AM
Subscribed.
CruiseControl 09-03-2008 08:44 PM
Trog: A little heads up with my experence in installation of the PMO ITBs on a '86 3.2 earlier this year
When ordering the ITB's I was questioned as to A/C being fitted. Answer YES.
Don't know what the difference would have been had I answered NO.
On fitting the right side air filter, it fouls the A/C condensor (above Cyl#4), and the A/C compressor is about 20mm too long fouling with the linkage at #4.
Solution was to remove the A/C condensor (still to fit some other condensor into the rear wing) and to use the shorter compressor from a 964 (Denso 10PA15C)
The left side air filter assembly also fouled the rear windscreen wiper motor (a very simple solution here)
The right side fuel rail rear fitting can not be used if A/C compressor is to remain. Added (welded) a fitting to both fuel rails just back from the ends. The sensor you see in the above photo on the LS rail is fuel pressure. Fuel temp is at the new regulator/return line. - previous fuel accumulator has gone.
I would suggest that if the vehicle is subject to higher levels of G forces effecting oil tank surge that a catch tank and vent / drain be fitted for the oil breathing system. Personally not happy with the breathing system supplied with the PMO kit.
The manifold to head "special nuts" 8mm nuts with 12mm spanner. The nut on the inner side of #4 port is all but impossible for any spanner type even a special.
I found the balancing of left and right side throttle benefited with a wide band O2 in each side. Using the recommended method still left a reasonable variance in A/F ratio between the sides when coming off throttle especially under greater vacuum.
The throttle position for mapping is a hugh change from the single throttle body. For example cruising at 100kM/Hr (62MPH) with the single throttle body was at a 22% position, where as the ITBs are now 5% open for the same speed/load. Hence mapping for fuel and ignition relative to throttle position is very different, now using fine resolution at lower throttle opening levels (e.g. 0, 1.5, 3.0, 6.5, 9.5, 12.5,15.5, 19, 22.5, 27, 32, 38, 45, 52, 60, 71, 84, 100). Prior to the ITB install the manifold vacuum tracked the throttle position. Now with the ITB's, atmospheric pressure in the intake can be achieved with 25% throttle at 4000rpm.
The vacuum manifold in the PMO kit works well with no pulsing.
Idle is great at 850rpm, (finish injector timing at 320deg BTDC for 0 throttle and idle speed)
Appreciate if you could detail the fitting of the Clewett cam sensor (near cyl#3) install with the engine in situ. I am presently running a sensor of the drive end of the left cam, and suspect that sensor to have an occassional problem. Have the Clewett cam sensor kit and would like to install with out engine removal.
Using the OEM head temp sensor in #3 as engine temp for cold start (and data)
Trog: we are all waiting your next report.
Paul
Larry_Ratcliff 09-04-2008 05:23 AM
Sweet! I have thought about running those on my 74. I am really curious to see the final outcome.
Trog 09-04-2008 08:09 AM
Paul
Paul,
Thanks for the very informative heads-up. In respect to fitment clashes, I've removed my AC compressor, bracket and condenser. In addition, I've backdated my heating system and have removed the blower. With hope, there won’t be any fitment issues.
Can you detail your oil "catch-tank" solution. I've you fabbed something up, pics would be helpful.
Are you monitoring/recording fuel pressure? Is this useful?
My next task will be to install the Clewett cam-sensor in-situ. I've scheduled that task for Sept 14th. I'll be sure to document the process in detail.
I can see that your tuning experience will be an invaluable asset. Great to have you on the forum.
Rgs,
Trog
Pic of current engine bay configuration:
http://forums.pelicanparts.com/uploa...1220540864.jpg
shahram 09-04-2008 11:13 AM
Very nice, great project.
Subd.
goldsc78258 09-04-2008 01:34 PM
subscribed
dfink 09-04-2008 02:55 PM
This is gonna be great. Mine just showed up today and the pictures don't do it justice. I however have to wait a few more weeks untill the heads and P/Cs are completed. So please document well because the life you save may be mine :)
Trog 09-05-2008 12:16 PM
Update
Played a bit more with the TECgt software... I can confirm that the O2 sensor can be configured on the basis of engine RPM and engine temperature. Meaning, the closed-loop O2 control will be disabled until which time a user set RPM and engine temperature are established.
Excellent!
Trog 09-14-2008 07:24 PM
Progress Report #3
After a week's hiatus, it’s time to get back to work. Today's task is to install the cam sensor. This is by far, the most time consuming and frustrating task.
To begin, you need to gain access to rear of the engine on the driver’s side. Seems simple enough, but to get to the cam, you’re going to have to remove the rear tin.
Here's a step-by-step procedure:
1. Raise the rear of the car high enough to get you and your beer gut well under the belly of the beast. Here’s a pic of the target area.
http://forums.pelicanparts.com/uploa...1221444923.jpg
2. Remove the driver's side exhaust header. No need to remove the muffler.
3. There are a number of fasteners that hold the rear tin in place. Most can be reached from under the vehicle, however there are two which are located just behind the drivers side intake manifold. I was hoping to keep the car on the road for another month or two, but I also have an unbridled desire to make some progress with the ITB installation. So I bit the bullet and removed the intake. Here’s a pic of the engine bay.
http://forums.pelicanparts.com/uploa...1221444965.jpg
4. My ultimate goal is to complete the ITB installation in a manner that will easily allow me to restore the vehicle without too much difficultly, so I took lots of pictures of the original installation. At this point, you’ll want to remove the speed and reference sensors. Be sure to label them in respect to their original orientation for future reference (you never know). Now’s a good time to replace your CHTS. The TECgt can accommodate the factory CTHS, so there’s no need to use the sensor that comes with the kit. Matter of fact, the TECgt connector will fit directly to the factory CHTS. With the speed and reference sensors removed, and the CHTS grommets pulled, the rear tin should slide right out. Here’s what it should look like:
http://forums.pelicanparts.com/uploa...1221445009.jpg
5. Figure on spending about 6-hours to get to this point. Of course if you have rusty fasteners, plan on more time. I now have to remove the cam-end plug, drill and tap a M5-0.8 hole and install the Hall-effect sensor. That task will have to wait for next week. In the interim, if anyone has a good method for removing the cam-end plug in situ, I would like to hear how you did it. I’m figuring I’ll have to design some sort of puller?
6. With the intake removed, now’s a good time to check for clashes. Place your ITB’s on the heads, and gently close the lid. Some have had issues with the AC. I can't be of much help as I've since removed my AC system in it’s entirety.
http://forums.pelicanparts.com/uploa...1221445106.jpg
Next weekend, I'll detail my report on the hall-effect sensor installation.
Oh, for your records, the Mahle fuel filter has a 14mm opening. You'll need this bit of info when you start designing your fuel delivery lines.
http://forums.pelicanparts.com/uploa...1221445067.jpg
dfink 09-14-2008 07:50 PM
Is there a reason that you removed the entire fitting from the fuel filter instead of just attaching to the existing fitting. And dang-it put some dirt on that engine. Mine is out for rebuild and doesn't look that good. Have the parts but no engine to sit them on.
Dennis Kalma 09-14-2008 08:34 PM
..you know for 6 hours of work I would have just dropped the engine. I can drop mine in about 2 hours. Makes a lot easier to work on and you get to clean it up easily at the same time....
Dennis
Trog 09-14-2008 10:06 PM
I'll be using "AN" type fittings for the fuel system. The Mahle filter is fitted with a metric fastener. I plan to use a 14mm metric to AN-6 connector in place of the Mahle fitting. It makes for one less potential leak source.
I'll see what I can do about the lack of dirt. Best of luck with your rebuild.
CruiseControl 09-15-2008 12:50 AM
Trog, Thanks for the update and detail.
I am also interested in the method of the end cam cover removal and sensor fitting
Please keep it coming
Paul
silverc4s 09-15-2008 01:28 AM
Trog,
Thanks for all the extra work putting this up for everyone. (subscribing)...
shbop 09-15-2008 07:24 AM
signing-up.
TimT 09-15-2008 10:29 AM
Try a slide hammer, thread a sheet metal screw into the cap, then attach the slide hammer, smack smack smack, and the plug should be out.
beepbeep 09-15-2008 10:44 AM
Nice project! I'm going to follow it from now on!
One question:
...do you have to use cam sensor and go trough whole process of installing a cam pickup? Can't you use existing dizzy pickup or just use Wastefire and just skip the cam sensor all together?
Also, are you planning to use Alpha-N only or run it in MAP/Alpha-N mixed mode? I believe mixed mode (+WBO2 feedback) would be easiest way to get good engine character at low throttle opening (assuming you get your throttles in sync 100%).
Regards
Trog 09-15-2008 12:09 PM
That's probably the way I'll go. Soon to be listed: "Slide hammer" only used once.
Trog 09-15-2008 12:14 PM
One question:
Regards
You only need to use a cam-position sensor if you want true sequential fuel injection. The system will work with the crank sensor alone, but not sequentially. Sequential injection requires confirmation of TDC on the compression stroke (hence the cam-sensor).
I plan to use the WBO2 eventually. It's probably best to start my tuning in open-loop and progress to closed-loop once I get the engine running properly. Stayed tuned for future tuning progress reports.
scottbooth 09-15-2008 01:46 PM
You may be able to borrow a slide hammer from an auto parts store. When I did the 2nd of my rear wheel bearings I "rented" a slide hammer from a local AutoZone. They got an approval on my credit card for some crazy "security deposit" amount for the cost of the tool and then tore up the slip when I returned the tool. Standard "tool rental" policy. But, I used the tool for free, and that's not bad.
The tool that I borrowed had a screw-on "foot" with multiple slots that I was able to use with the studs on the wheel hub. With a couple of washers and some minor hassle ,this may work with your sheet metal screw threaded into the cap, as suggested above.
ITB EFI is on my to-do list (kinda low due to cost but whatever) for my SC track car, which runs OK with my mostly-functional CIS but could do better, I think. So I am watching closely and wishing you the best.
Good luck,
Scott
