With ITBs an idle control valve is kind of difficult. You end up setting idle speed by adjusting the throttles. Not a value entered in the ECU
TimT and Trog thanks for the info. I couldn't figure out how it would be done so I guess one less thing to worry about. Plenty of others.
You could achieve some idle control and stability by simply doing it via idle ignition map. I currently do this in my 3.2L Motronic in addition to the ICV.
The idea is to set the ignition to some value that works well at the target idle. For example: say the target idle is 880RPMs and the ignition is set to 0deg. Then in the map you simply advance the ignition if the idle drops below the target and retard if the idle increases above the target. In my car the target idle is 920RPMs and ignition is set to 5deg BTDC if the idle drops I start advancing the idle as much as 11deg BTDC if it drops to 800RPMs. Then I also retard to -3deg ATDC if it increases to 1000RPMs. You would be surprised how much you can influence the idle by simply altering the ignition at idle. Adjusting idle in this manner also compensates much faster than a mechanical ICV valve. I'd hope that any modern day Engine Managment System could do this. |
The TECgt allows for TPS input for idle purposes. Should the MAP prove to be excessively erratic at idle (due to Hi perf cams), then it's an easy matter to dial in TPS sensor inputs.
Common causes for idle drift are things like Alternator Load and AC Load. Without idle compensation idle often will drift/drop by simply turning on the headlights which cause Alternator Charging system load. |
What are all the little cams for that come with the TPS?
As you reported, the timing map would address any drift. |
Little engines? :D Are you making reference to the throttle linkages? |
In the package with the throttle sensor were several little round clips that look like cams. Looked up the CTS TPS sensor on the internet but they didn't show them. The TPS just attaches direct to the throttle shaft from what I can tell. |
T... |
http://forums.pelicanparts.com/uploa...1225242834.jpg |
Trog,
I saw your video, very nice to have it running now. Did you start monitoring with your WBO2 yet? If so what's your AFR at idle? |
After 5-minutes running, it gets to 12:1 The cold engine enrichment bias appears to be a tad generous. Plus, the ambient air is pretty cold up here this time of year (approx 10degC). I plan to start tuning this weekend. T... |
Once warm at idle (open-loop no O2) I have it set to AFR=14.2 and this makes for nice smooth idle. I also found that idle timing between 0 to 5 deg advance works well for idle. Hope these help. |
First Driving Impressions
With the help of Richard Clewett, I’m now ripping up and down the street logging data for fine tuning. The idle AFR was much too rich, so I had to reduce the IOT value. (“IOT” is the value in the TECgt that is equivalent to the idle jets in a carb). I still need to set the TOG value correctly in order to set the base-line fuel curve. However she’s running pretty good as-is.
First driving impressions...... Well I don’t really know if the car is any faster, but the sounds out the rear are sublime!!!! Sounds like something out of Formula-1. Throttle response is instantaneous. My neighbors are going to hate me. Trog |
Trog, this is one of the most informative threads I've ever seen in almost 5 years on this site - outstanding work, and many thanks for documenting all this for us.
Anything interesting new to report? I'm curious how the tuning went. |
Two hours at a dyno and you would be done. I tried the bring it in slow method didn't work well, too slow. Then Richard said I had to find the maximum first in your case TOG in my case UAP. That means full load pulls all the way to what ever you decide on for redline. Then back down load to make sure that is OK then back high again. The VE table should be nearly all 0 when completed. My only problem right now is that when I am doing really hard full loads my cylinder head temp reading is going to 5V and fails. Not sure what it will read on a track. This is only on a dyno. Oil temps all look pretty good. I am using an old factory sensor which may also be part of the problem. |
| All times are GMT -8. The time now is 07:22 AM. |
