brake booster
my car comes without it originally
can i fit one to my 911 1976?
do i need only stock porsche or can i use others?
911 TARGA 1976 - 3.2L, G50 SHORT BELL HOUSING.
Toyota Hilux 4x4 2000
VW tuareg 2009 3.6
HONDA SH350
Old 09-19-2008, 11:51 PM
300hp 1800lbs is the goal
pksystems's Avatar
bump..... I wanna know too.... but for a '66
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 09-20-2008, 12:40 AM
Bill Verburg's Avatar
adding a booster to a non boosted car is a very involved process that entails mods to the firewall
You can get an idea of how involed by looking here
Bill Verburg
Old 09-20-2008, 06:28 AM
e p slick's Avatar
boost
I converted earlier 911 to a boosted system and found it a very straightforward procedure. Bought later model pedal assembly with actuating rod on eBay for $50.00. Bought aluminum base + booster for another $100.00 as I recall. Bought new master cylinder from Pelican. Utilized .250" aluminum plate @ probably
8" x 12" for bolt-in no flex platform for booster / MC assembly, took my time measuring and put the whole lash up in the car. It was very straightforward, worked very well and was by no means difficult. The end result was not something a Porsche purist would endorse, naturally, but, then again the car also had a "Not-A-Porsche engine in it.
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 09-20-2008, 07:03 AM
