ajmarton's Avatar
Need Help figuring which horn to replace...
Ok, I have a 1989 911 Cab and am working on the oil cooler in the pass front fender. I noticed that one of my horns is broken. It is the one to the outside of the fender (not the one closest to the side). I can't figure out if it is the high or low pitch horn. Any ideas? Andrew
Old 09-02-2008, 08:53 PM
the horn with the longer trumpet is the low pitched one and the shorter one is high pitched.
a little of this + a little of that
Old 09-03-2008, 05:01 AM
if it is the actual trumpet portion that is broken and you can't compare them together it is only one nut to remove the horn in question and IIRC the part # is on the back of the electrical portion near the stud used to attach it to the car.
Old 09-03-2008, 05:06 AM
3.2 CAB's Avatar
1974-1989 models
911 635 102 20--- low pitch
911 635 101 20---high pitch
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-03-2008, 08:10 AM
If one doesn't work, put your hand on the horns while someone else honks it.
You can feel which one works.
Old 09-03-2008, 08:18 AM
At the track = great day
ChkbookMechanic's Avatar
tcar's explanation is right on how to figure out which one isn't working. However, wouldn't it be easier to get a new horn that was louder so people will actually be able to hear it?
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 09-03-2008, 08:34 AM
ajmarton's Avatar
Thanks. I will remove the horn and check the part number as it is the trumpet that broke off one horn.
Old 09-03-2008, 08:35 AM
jwash's Avatar
which horns are most people using?
Old 09-03-2008, 09:03 AM
