Need Help figuring which horn to replace...
Ok, I have a 1989 911 Cab and am working on the oil cooler in the pass front fender. I noticed that one of my horns is broken. It is the one to the outside of the fender (not the one closest to the side). I can't figure out if it is the high or low pitch horn. Any ideas? Andrew
the horn with the longer trumpet is the low pitched one and the shorter one is high pitched.
a little of this + a little of that |
if it is the actual trumpet portion that is broken and you can't compare them together it is only one nut to remove the horn in question and IIRC the part # is on the back of the electrical portion near the stud used to attach it to the car.
1974-1989 models
911 635 102 20--- low pitch 911 635 101 20---high pitch
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
If one doesn't work, put your hand on the horns while someone else honks it.
You can feel which one works. |
At the track = great day
tcar's explanation is right on how to figure out which one isn't working. However, wouldn't it be easier to get a new horn that was louder so people will actually be able to hear it?
Lane 2011 Volkswagen Jetta SportWagen TDI Looking for another sports car.. |
Thanks. I will remove the horn and check the part number as it is the trumpet that broke off one horn.
which horns are most people using?
