71E resto progress..powder coating is good.
Picked up a batch of parts that I had powder coated. (Skagit Powder Coating....this is in mount Vernon, WA....info for the PNW locals) The engine for my 71E moves forward......next week i get all my hardware back from the platers (yellow zinc plating) and the engine will be complete and the re-assembly moves forward. Front suspension, gas tank, brakes are next. ![]() ![]() ![]()
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Wow,
looks awesome.....were you happy with the results?
1977 Porsche 911S (Widebody) |
That looks super good Al!
James 1969 911E Slate Grey 1981 911SC Wine Red 1997 911C4S Ocean Blue |
al,
i see you pc'd the a arms. what bushings are you going with? i'm torn between a quick strip and rattle can respray, keeping my old bushings vs powdercoat and replacement. curious as to your thoughts.
bob 1972 E pos correction: expensive pos someday.... "shut up and drive!" |
Tony,
Yes...i'm happy with the results. Andy and co. did a nice job and the cost was reasonable. James, Thank you. Bob, I struggled with that one. I have heard the pro's and con's regarding most of the other bushings. I though that my stock, rubber bushings were in decent shape and could probably have been retained. I finally decided that freshening them up was the right decision and in keeping with the rest of the resto work that I'm doing on this car. I have Neatrix bushings on my 77S spring plates and trailing arms and have not heard one squeek out of them, after two years of use. I think that I will go that route, or equivalent, with these A-arms. I will probably add grease fitttings to them, as well. P.S....while i thought that my rubber bushings were ok, once I got them off they looked pretty worn.
