Send a message via MSN to P Moore Send a message via Skype™ to P Moore
Connections on CIS Injection ??
Hi,
Can anybody point me in the right direction here with the wiring,
This is the last job before i get the engine back in !
You can see in my clip that there is 2 blue and 1 black connecter,
This is where im mixed up....there is 2 blue and the connections are the same, and then there is 1 black, so i figured that the black goes to the black ???
But then i was looking through the engine rebuild book and im pretty sure the Wayne had a picture of the black connecting into the blue !!
Take a look at this clip and let me know.....
[IMG][/IMG]
Old 09-07-2008, 03:59 PM
CIS works only then starter is on
Old 09-07-2008, 04:54 PM
CIS Wiring connections......
P Moore,
From watching your clip, you got the right connectors for the following:
Air sensor plate switch: brown and brown/red
Cold start valve: yellow and red/brown
Auxiliary air regulator: red/white and brown
These are applicable to '76-'83 (911) CIS models. What year is your engine? HTH.
Tony
Old 09-07-2008, 06:43 PM
I was trying to find this out .....
The casing has been replaced and there is no engine number....at first i was told it was a 2.7 but from pictures i sent to a friend over there he has told me that it is a 3.0 he said he knew this by looking at the flywheel ???
So do i have these connections correct ???
Old 09-08-2008, 03:12 PM
P Moore,
Yes. Based from the clip you have shown, the connectors are in the right spots. How about the 14-pin connector? If you need additional info regarding the 14-pin connector of the wiring harness just PM me. You should be ready for start-up.
Tony
Old 09-08-2008, 04:12 PM
that should be ok as i never messed around with it !! I just took the loom off and kept it safe and re-wraped in tape,
Before i get her back in i have a MSD unit to install, i thought it would give me more room to install this when the engine is out,
I have been told i needed the following:
Msd - 6AL,
Tach Adapter (msd)
Then im waiting on the pertronix, ...getting rid of the points...
Old 09-08-2008, 04:55 PM
