christojen's Avatar
Is the search function working??????
Hi all,
no matter what i search for, i get zero matches back. TGhis is really annoyng as i know there is heaps of good info here. I put in a key word, and select the 911 tech forum, and always get nothing>>>> What am i doing wrong???
TIA
Chris
Old 10-18-2008, 01:26 AM
UnRegistered User
billybek's Avatar
Seems to be. Just did a quick search and the related threads popped up, no problem.
Try something simple like "fuch" just to check if it is working.
Make sure you are searching the forum, not a thread.
Bill K.
Old 10-18-2008, 06:48 AM
give me an example and I'll try it here - I searched "Tire Rack" and got results.
Old 10-18-2008, 06:49 AM
3.2 CAB's Avatar
The only problem that I have encountered with the search feature lately, is when doing a search, it would only show threads or postings in 2008. I was trying to find one of mine that I posted several years ago, and the earliest it showed was in Jan. 2008?????
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-18-2008, 12:54 PM
I just tried finding posts by me using the advanced search tool... got hits to 2005
Old 10-18-2008, 01:34 PM
Author of "101 Projects"
Wayne 962's Avatar
It will only return the first 500 matches. If you want more, then please make your search more specific. This is done to preserve server resources.
A person cannot search on "wheel" and expect to get any reasonable responses. Yet, a lot of people do this, and ironically, a search on a non-specific term like this uses a lot of resources on the server.
-Wayne
Old 10-18-2008, 03:26 PM
Zeke's Avatar
Didn't there used to be a search tutorial? I'd like a refresher on using quotation marks and the plus sign, if that does anything. If I searched for tire rack, I'd expect to see 500 threads with the word tire in them but not necessarily rack. I think I have better luck using Google. Google turns up a lot of Pelican threads.
Old 10-18-2008, 03:46 PM
christojen's Avatar
Thanks i think i was searching threads, and also not specific enough. I tried your suggestions and got results.
Thank you very much,
Chris
Old 10-18-2008, 04:11 PM
