AAR Question
Does the 12vDC source to the AAR provide continuous current as long as the engine is running? I can't find any reference that indicates the power for the AAR is on a time limit.
Thanks, Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure. 2009 Cayman |
Auxiliary Air Regulator.......
Jim S.,
The AAR, WUR, thermovalve, and FP for SC's are all getting power from terminal #30 (FP relay socket). When the FP is energized, others are also energized at the same time. Refer to wiring diagram/s and it will help you understand the concept. HTH. Tony Last edited by boyt911sc; 09-13-2008 at 09:28 PM.. |
If I'm understanding the wiring-
As long as the fuel pump is energized, power is applied to the AAR. Is this a correct statement? Thanks, Jim S.
I say we take off, and nuke the site from orbit. It's the only way to be sure. 2009 Cayman Last edited by jmshepard; 09-13-2008 at 07:50 PM.. |
The answer is......
Tony |
