Senior Advisor
Well I started down that road to fun and games (read hell) with a Rennspeed yellowbird front and rear bumper upgrade. Removal of the old parts went fine (wow, that rear bumper is heavy!!) and installed for a trial fit. The parts fit pretty good with the exception of the front signal lamps. total crap, had to cut out the fiberglass mounting tabs and will have to glass in new mounts. But overall not too bad. the first time I put the bumpers in place, my heart skipped several beats! just keep working it and it will work. Now it's fit and finish time. Also installing a 964 motorized spoiler and debating on adding the 3rd cyclops stop light or going with the inside window lamp. The front bumper will have air ducts glassed in and a front mounted oil cooler added. here are some pics of the fitted bumpers
08 Cayenne Turbo |
Sultan of Sawzall
Looks great! Now just get yourself a 964 smilie to trim it out and tie the front end together!
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Max Sluiter
NO THIRD BRAKE LIGHT!!!
![]() Those stalks are SO ugly. Sorry for yelling. Keep your car's cool clean lines. I love the color.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
those bumpers are badas$, whered you get them from? by the way, looking great so far. have you thought about putting on a ducktail instead?
'14 Cayenne GTS '04 996 Coupe '02 C4S Coupe '99 M Coupe '84 M491 Coupe |
Senior Advisor
the bumpers are from Rennspeed. a 964 smile.....never thought of that
08 Cayenne Turbo |
Sultan of Sawzall
Yes, I used the 964 smilie on my wife's white 3.2 with the same front end. Fits perfectly!
Might I suggest a thinner trim treatment. You already deleted so much rubber, why add more. Here is the TRE/Axiom solution. I like a lot, and its pretty simple. The 964 smile may be more aerodynamic, but this looks sweet. If I do say so myself. Looking good!
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
Senior Advisor
l love it!
08 Cayenne Turbo |
This Way Up
I have a similar solution to Jim's (done by PO) and also think it looks better than the 964 smile. I won't be able to post a pic for a couple of days, but will do so asap.
a.k.a. G-man
+1 go for the inside brakelight. Car looks great!
Сидеть, ложь, Переворачиваться |
This Way Up
found a pic - I'll send one with more detail in a couple of days.
Senior Advisor
thanks guys, that looks great
08 Cayenne Turbo |
I'll second the notion of not installing the "cyclops" third brake light. As for the one mounted on the inside of the upper part of the rear window, I'd strongly suggest you don't do that either. The placement blocks all of what you wnat to see to the rear, when on the highway. It's very annoying.
Otherwise, carry on. JR Last edited by javadog; 09-18-2008 at 01:24 PM.. |
Senior Advisor
thanks yes will go with the hella LED unit that mounts on the lower inside rear window
08 Cayenne Turbo |
