-   -   Carrera Graphics Install Early Car. Need Help. (http://forums.pelicanparts.com/porsche-911-technical-forum/431415-carrera-graphics-install-early-car-need-help.html)
rennch 09-20-2008 04:20 PM
Hi all,
According to this image, the Carrera graphics start about 50mm up from the bottom of the rocker cover. But, on the early cars, I have no rocker cover. Does anyone have the correct measurement for me?
http://forums.pelicanparts.com/uploa...1221952827.jpg
Brian 162 09-20-2008 06:08 PM
I measured mine 2 inches from the bottom of the door.
rennch 09-20-2008 06:41 PM
Brian...pictures?
Elombard 09-20-2008 08:16 PM
I looked at the R, RS, RSR book and estimated it from some reference point (cant remember) in the pictures. The bottom of the decal roughly lines up with the wheel centers.
Brian 162 09-21-2008 12:44 PM
Here you go.http://forums.pelicanparts.com/uploa...1222026062.jpg
http://forums.pelicanparts.com/uploa...1222026097.jpg
http://forums.pelicanparts.com/uploa...1222026146.jpg
http://forums.pelicanparts.com/uploa...1222026191.jpg
http://forums.pelicanparts.com/uploa...1222026247.jpg
André 3.0 09-21-2008 01:15 PM
check this treat Stickers DIY
http://www.porscheforum.nl/viewtopic.php?p=230316#230316
http://www.porscheforum.nl/album_pic.php?pic_id=19586
use some tape,5 cm wide at the bottom from the door
http://www.porscheforum.nl/album_pic.php?pic_id=19596
please wait 24 hours before removing the backing foil...............good luck :D
bluesky 09-21-2008 02:07 PM
I thought that the top of the decal stripe should be on the same line as a line that runs from the tops of the front & rear bumpers of a longhood car....imagine a line strectching from the fender/bumper seam in the rear going to the fender/bumper seam in the front....the decal top matches with this line......however, the stripe on an impact bumper car is lower.
rennch 09-21-2008 03:36 PM
ok...so maybe 2" from the bottom of the door is just for short hoods. Anyone have longhood pics or techniques?
Joe Bob 09-21-2008 03:47 PM
Check out my website.....I have installation instructions.
rennch 09-21-2008 04:52 PM
Hey Mike...it's not about the install as much as the placement location. Thanks for posting those though....very helpful.
Joe Bob 09-21-2008 07:00 PM
I also have 3-4 pics on the website that shows the typical location.....
rennch 09-21-2008 07:04 PM
Well, it's hard to tell mm from pics. :) Thanks though.
Joe Bob 09-21-2008 07:20 PM
If you have a longhood, envision a one inch border on the bumpers....like the chrome strip or on an RS a vinyl strip.....
Center THAT strip in the middle of the Carrera Bars on each end. THAT is the proper height.
rennch 09-21-2008 07:33 PM
mike...is the "strip" in the center of the bumpers?
Man, it sure would be helpful if someone had a pic of an early car with carrera graphics. :)
Joe Bob 09-21-2008 07:56 PM
http://forums.pelicanparts.com/uploa...1222052183.jpg
http://forums.pelicanparts.com/uploa...1222052198.jpg
http://forums.pelicanparts.com/uploa...1222052211.jpg
rennch 09-21-2008 08:00 PM
Thanks Mike...that's helpful. I see what you're talking about now.
Also...I need the "Carrera RSR" graphic file for the ducktail. Can I buy that file from you so I can get it to match my vinyl?
Joe Bob 09-21-2008 08:14 PM
RS or RSR? I should be able to cut that....black doesn't have many different shades....
rennch 09-21-2008 08:17 PM
If I was using black I would have gotten the graphics from you in the first place. :)
Joe Bob 09-21-2008 08:20 PM
What color ARE you using?
rennch 09-21-2008 08:24 PM
It's a grey a couple of shades from the color of my car. Subtle.
