Rennch on YouTube
Carrera Graphics Install Early Car. Need Help.
Hi all,
According to this image, the Carrera graphics start about 50mm up from the bottom of the rocker cover. But, on the early cars, I have no rocker cover. Does anyone have the correct measurement for me?
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
Retired Member
I measured mine 2 inches from the bottom of the door.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Rennch on YouTube
Brian...pictures?
I looked at the R, RS, RSR book and estimated it from some reference point (cant remember) in the pictures. The bottom of the decal roughly lines up with the wheel centers.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Retired Member
Here you go.
Carrera 3.0 1975
check this treat Stickers DIY
http://www.porscheforum.nl/viewtopic.php?p=230316#230316 use some tape,5 cm wide at the bottom from the door please wait 24 hours before removing the backing foil...............good luck
I thought that the top of the decal stripe should be on the same line as a line that runs from the tops of the front & rear bumpers of a longhood car....imagine a line strectching from the fender/bumper seam in the rear going to the fender/bumper seam in the front....the decal top matches with this line......however, the stripe on an impact bumper car is lower.
Rennch on YouTube
ok...so maybe 2" from the bottom of the door is just for short hoods. Anyone have longhood pics or techniques?
RETIRED
Check out my website.....I have installation instructions.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 09-21-2008 at 03:50 PM.. |
Rennch on YouTube
Hey Mike...it's not about the install as much as the placement location. Thanks for posting those though....very helpful.
RETIRED
I also have 3-4 pics on the website that shows the typical location.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Rennch on YouTube
Well, it's hard to tell mm from pics.
Thanks though.
RETIRED
If you have a longhood, envision a one inch border on the bumpers....like the chrome strip or on an RS a vinyl strip.....
Center THAT strip in the middle of the Carrera Bars on each end. THAT is the proper height.
Rennch on YouTube
mike...is the "strip" in the center of the bumpers?
Man, it sure would be helpful if someone had a pic of an early car with carrera graphics.
RETIRED
Rennch on YouTube
Thanks Mike...that's helpful. I see what you're talking about now.
Also...I need the "Carrera RSR" graphic file for the ducktail. Can I buy that file from you so I can get it to match my vinyl?
RETIRED
RS or RSR? I should be able to cut that....black doesn't have many different shades....
Rennch on YouTube
If I was using black I would have gotten the graphics from you in the first place.
RETIRED
What color ARE you using?
Rennch on YouTube
It's a grey a couple of shades from the color of my car. Subtle.
