plymouthcolt's Avatar
Rattling noise-transmission going bad?
I have a strange noise which I sounds just like a loose heat shield. I crawled under the car and pulled on the heat shield for the cat and it does not budge. In fact the bolts holding it are rusted solid.
If you have ever heard a loose heat--it sounds exactly like that. As I accelerate from a standstill I hear it through all gears and rpm ranges.
I am going to change the gear oil this weekend and look for any excessive metal shavings or debris.
Any ideas on the cause? I hope I am not looking at a transmission rebuild on my G50.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 09-23-2008, 04:41 PM
dshepp806's Avatar
This noise came on quickly? You sure it's not the frikin' chain rattling?
Gear oil changeout can't hurt...is the shifting still smooth?
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-23-2008, 05:10 PM
burgermeister's Avatar
Below about 2000 rpm I think it's normal for the G50's to have gear rattle.
At all RPMs sounds a bit odd to me.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 09-23-2008, 05:12 PM
Zeke's Avatar
Mine doesn't.
Old 09-23-2008, 05:28 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Here you go 88 G50,
I was going to do this to my 85 915 but I realized it does not apply to my baby.
Maybe this could be your issue:
1. Rubber O Ring
2. Insulation Hose 700MM
or
3. Rubber Washer
Here is the thread I found: Is a chattering sound normal starting out in 1st gear? '88 Carrera
'85 Carrera Targa
PCA/POC
Old 09-24-2008, 12:18 AM
