1984-911 M491
ITB's - How do they work
How is air-flow measured with ITB's? Does the Motronic (or equivalent) controller still need an air-flow signal to meter the correct amount of fuel?
Just wondering...
1984-911 TLC......SOLD |
PRO Motorsports
With no airflow meter, the computer relies on the throttle position sensor, intake air temp sensor, rpm, and manifold pressure (MAP) sensor to "estimate" the engines fuel requirements.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
1984-911 M491
So I guess I have to trash the Motronic and replace with aftermarket computer?
That is what I did!
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
My 3.4 runs on a Micro tech. Very stable, reasonably priced and easy to use soft ware.
Cheers
what throttle bodies are you using?
jenvey
1984-911 M491
Can I continue to use the Motronic to control ignition, and use another controller for the ITB fuel delivery?
I'm considering acquiring a used kit consists of Jenvey ITB and Haltech F10 ECU among other stuff.
'87 3.2 Targa |
I am going to use one of these when I get around to it to replace my AFM, www.mapecu.com, just wish i had the time to tinker.
'89 911 M491+Turbo '90 964 C2 '89 944 Turbo '88 928S4 |
