Fuch for Spare
Is there any size Fuch wheel and tire combo I can use to replace my factory spare in my 1979 911 Targa?
yep, I think a 15 with the space saver on it. Others will chime in I'm sure.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
A little off topic, but I used a BBS 3 piece race wheel (15").
jp ![]()
15x6 works fine;
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
You can use any 6 x 16 Fuchs and 16" rubber from a 993 spare...fits too. There are some threads on this.
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
FYI.
One Fuchs is Fuchs, plural is also Fuchs. Fuchs is German for Fox. Must have the 's' on the end or it's not a word. |
14", 15", and 16" Fuchs all can work. I have a 14" Fuchs as my spare.
For those of you that have done it, did you have to put an extra bead on the rim or would a space saver fit straight on the wheel?
88 carrera Using the teutonic shift method since 1990. |
a 6X15 with a 195/50/15 is a good choice too.
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Byron, Could you post a picture of the shoe horn you used to wedge that bee otch in? ![]() Does it fit correctly? Thanks.
![]() Anyone who has driven on a a temp knows how much it sucks
