I just read on TireRack - using anitsieze on wheel lugs
sorry if this has been thrashed to death on another thread.. mod. move over there if yes.
I put anitsieze on my studs and wheel nuts - haven't noticed any issues - I take my tires on and off frequently compared to the average driver. I see this on the TireRack website... NOTE: We suggest removing the wheel and applying a thin coating of "antiseize" around the axle hubs to help prevent rust and permit easier removal when it’s time to rotate your tires. Do not apply "antiseize" to the lug hardware or studs |
they're talking about steel (rust). we know how aluminum lugs can bind to aluminum wheels, and how the lugs get torn up eventually, going on and off the steel studs.
agreed.. something for sure needed for AL nuts on steel studs... I use steel nuts now and have my nice black AL ones in a bag somewhere... I use copper anti-sieze on everything - reduce wear, reduce any rust, provide nice constant torque - nothing has come off on the track or street....
I think the issue is torque specs are determined (unless noted) dry...well actually with a light machining oil (I believe) and when you add grease, anti-seize, etc 95 ft lbs (for a Porsche at least) will actually stretch the stud beyond what it was designed for. 95 ft lbs without anti-seize is lower tension on the stud than 95 ft lbs with anti-seize. So many folks are using some sort of lube to prevent rust and I don't think anyone is having an issue.
'83 SC |
It seems they are talking about how aluminum wheels get stuck on the steel hub flange and then you can't get the wheel off. I've had cars where you remove all lug nuts and you have to take a peice of wood and hammer to unstick the rim from from hub..
1980 SC 71 Chevelle SS454 |
agree - bolt tension is more with same torque and various types of lube... I doubt the increase in tension will over stress the bolt...the situation is helped somewhat because the total stress on the bolt is a combination of tension and torque... the tension is more but the torque is less. The science of this may not to totally straightforward.
This has been discussed a zillion times here. The short answer is that Porsche specified a certain torque value for the lug nuts based upon the assumption that you would be using what they recomended for the "anti-seize." They indicated in a technical bulletin the you should use Castrol Optimoly Paste (HT, if I recall correctly.)
Different lubes, or none at all, will give a different bolt stretch at the same indicated torque value. You might have too much, you might have not enough, you'll never know. Since it is so easy to do what they recommend, I wonder why so many people choose to go their own way. JR |
JR - ok thanks that pretty much nails down what to do with the stock AL nuts... just wondering re. steel on steel - I guess I'll do a search.
Keep in mind that when using a steel nut with a Fuchs wheel, you have an area of steel to aluminum contact, so it's not just steel on steel. I can't help you there.
JR |
yes I realize this and usually put a very small swipe of anti-sieze around there. sometimes I see a bit of AL flakes coming off still so I need to watch out
if you read - TR mentions both... anti - sieze on hubs/etc. and then mention "dry" for lug nuts... the interesting thing is I consider TireRack to be some sort of non trivial source.. they can be wrong or maybe just wrong interms of people like us that use torque wrenches and take the tires on and off frequently.
The 84-89 Bentley says
Rick 88 Cab |
tcar - there we have it.. a clear controversy - the question is not resolved.
I always put plenty of anti-sieze on the wheel hub and the area that it contacts on the wheel. If you've ever tried to get unlubricated snow tires/wheels off after a long winter and you finally have to resort to a sledgehammer, you'd do it too.
Stephan Wilkinson '83 911SC Gold-Plated Porsche '04 replacement Boxster |
I don't think there is any controversy re. putting something on the hub/mouting ring surfaces. It is a good idea. There is no controversy re. putting anti-sieze on AL nuts on steel lugs... this is closed due to Porsche written bulletin. The remaining controversy is using anti-sieze on steel nuts on steel lugs.
Somatic Negative Optimist
![]() Please, we've been through this a few times. ![]() In industrial applications, torque specs are always "WET" meaning: with lube, unless specified "DRY". Thread-locker qualifies as "WET". So, when you read 95 ft-lbs for lug nuts, it's with lube, not just on the threads, but also on the mating surfaces like the concave/convex area of the lug nuts. If lube is not used, the right torque cannot be obtained because steel-on-steel, or metal-on-metal, has too much friction. Using a little grease on the mating surface of an Alu-wheel to a steel hub is good practice to prevent corrosion.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
![]() Go with lube if you like your lugs and wheels and check the torque more often. Example for torque with lube are the head studs: The barrel nuts with 24-25 ft-lbs don't come lose, the studs usually pull out.
if the go dry crowd wants to continue discussion - please provide references other than it worked for me |
AutoBahned
OR you can do what the highly paid engineers at P AG explicitlt tell you TO DO! if the duh? bell is still going off in your brain, reread gunter, jww & jr's comments the tsb fdrom p ag is very clear on where to use it - hit search Last edited by RWebb; 09-22-2008 at 11:12 AM.. |
