Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I want to cut this wire...but I am afraid!
This is a picture of the wires in question. I believe they went to the seatbelt. I am putting together a PCA Club Racer of sorts and I was hoping to clean up the floor a bit before putting it all back together. Can I cut this wire? Specifically the brown and yellow wire the top arrow is pointing too.
I was going to pull the connectors from the yellow wires and shove the whole bundle down in the hole it originates from in the tunnel.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 10-03-2008, 02:27 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Those wires look like my Engine Heater Fan switches. Since you are racing I assume you have removed the heater?
My 2 cents
'85 Carrera Targa
PCA/POC
Old 10-03-2008, 04:21 PM
Draco is correct regarding the yellow wires. The switch on the end is actuated by the two heater levers next to the e-brake. If that switch is serviceable, I'd take it off your hands.
I'm not sure what the other wire is.
Old 10-03-2008, 04:46 PM
I suspect the brown/yellow wire might go the the emergency brake switch.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 10-03-2008, 05:31 PM
Black and Blue
Kemo's Avatar
thanks for the input guys...the two yellow wires are just hanging on a connector of sorts and the brown/yellow stripe goes under to the end of the parking brake.
Kemo
Old 10-06-2008, 02:42 PM
