Throw it on the ground!
Gas Shortage in ATL - Can I run Reg vs Premium?
There has been no Premium available in Atlanta this week. Stations are only getting Regular, not even mid grade.
Any problem running a tank or two of regular if I have to until supply is available?
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 09-24-2008, 03:09 PM
crustychief's Avatar
I always run regular (.)
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-24-2008, 04:40 PM
E-man930's Avatar
mix in a bottle of lucas octane booster and you should be ok...
Old 09-24-2008, 04:43 PM
Just keep your foot out of it on regular. That is hard to do in a 911.
Old 09-24-2008, 05:14 PM
Make Bruins Great Again
Por_sha911's Avatar
Find some AV gas and mix it in. Go to the nearest small airport and see what they put in the two seaters.
Joe
Old 09-24-2008, 05:21 PM
autobonrun's Avatar
Same here for almost 25 years. Nothing by 87 octane in my SC; no difference in performance. I'm not sure if a Carrera will perform different with lower octane. If 87 was all they have, I'd try a little to see how it runs. You can always blend in the premium once it's in stock again. I don't think there would be any damage. The worse case you'd just park it until the premium returns; same as if you don't have any in the first place.
1979 Porsche 911SC Targa
1996 Porsche 993 C4S
2005 Porsche 996 Turbo S
2020 BMW X3M Competition
2003 BMW M5
Old 09-24-2008, 05:26 PM
tdatk's Avatar
Your car was designed to run on 87 octane (91 RON) . Unless you are running a chip or high compression heads.
Tim
82 SC
90 C2
Yasowatt
Old 09-24-2008, 05:45 PM
khamul02's Avatar
A 79 can run on 87 octane. It should not be used in an 87. Try the octane boost. If you start hearing pinging stop running it.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 09-24-2008, 05:46 PM
RF5BPilot's Avatar
Note that "AV gas" is "100LL" -- 100 octane "low lead" -- which (despite its name) contains high amounts of lead. If you want to destroy your catalytic converter as well as muck up your engine over time, 100LL is a great way to do it.
James
Old 09-25-2008, 06:44 AM
db_cooper's Avatar
I have the same issue here in Atlanta. Use the site www.gasbuddy.com and find the map, select "premium" then "last four hours". Report will come up as to who has high test fuel and where it is. You would be surprised. Just tanked up my 911 3.2 over on Moreland Ave. No line. Amoco too!
Old 09-25-2008, 06:55 AM
Monkey Butt Forespin
84_Carrera's Avatar
Check into the fuel setting switch on the DME. There's a way to retard timing for poor grade fuel, not sure how that works if you have a chip. If that helps you out, then switch it back when all's well again.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 09-25-2008, 06:56 AM
3.2 CAB's Avatar
I find something very strange about the gas problems that some areas are having. Here in South Mississippi, reg gas went down to $3.16 yesterday, now today is has dropped to $3.04 what the hell is up with that??????
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 09-25-2008, 08:15 AM
I have a feeling the entire price jump to 4 bucks a gallon was just to get us all used to saying "wow gas is only $3.04 per gallon!" Just a year ago that was the price we were all screaming about.
Old 09-25-2008, 04:16 PM
gtihop's Avatar
$3.04 a gallon. I wish. Try $6.50 a gallon for reg here in Canada!
1983 911 SC
2015 Volks GTI
1991 Volks GTI
2011 Nissan Juke
1992 Nissan NX 2000
Old 09-25-2008, 05:22 PM
boxster03's Avatar
And your not bothered by this in the least
What country is this
Bahhhhhhhh Bahhhhhhhh
Are we not men
Maybe a $trillion loan to WB and GS will help you sleep at night
Ouch this is going to hurt
Now back to the Porsche wave
Member #750 Early911S Registry
1970 911E
I know Where Jerry S. has his NYC Garage
Yadda Yadda Yadda
Old 09-25-2008, 05:25 PM
Por_sha911's Avatar
Sorry, I should have stated that my car doesn't have a cat. Will a little lead (say 5 gallons AV mixed with 15 regular) for a week muck up an engine?
Buzz, wrong answer, thank you for playing. You won't always hear pinging. You could be doing damage and think all is well.
Joe
Old 09-25-2008, 06:26 PM
T77911S's Avatar
i put in a set of colder plugs and have been using 87 gas with good results. if that does not help, you need to retard the timing, not the best option but at least you can drive it.
check the ngk site on plug heat ranges and effects.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 09-26-2008, 04:04 AM
A '79 and an '87 are very different. The most important factor is the difference in compression ratios of the two motors. An '87 (even a US model) has a higher comp ratio than a '79. Higher compression usually requires higher octane to avoid detonation.
There may not be any damage, but there can be. Detonation can destroy an engine. You can't necessarily hear detonation.
Old 09-26-2008, 05:55 AM
Update: Still no premium available in Atlanta. Regular or Diesel only and it still tough to find with long lines when you do. Waited 1 hour in line Sunday filling up the wifes SUV and observed a near fist fight in line - tempers are flaring.
I was able to top off the 911 with regular again at QT on the way home from the office. Then stopped at three Auto Parts stores - all were sold out of octane booster & gas cans. Its a friggin mess! It may be another week or two before supplies return.
Mark
1987 911 Coupe
Old 09-29-2008, 04:51 PM
khamul02's Avatar
Dude, I'm bringing the car into Atlanta on Wednesday night from Mississippi. Do you know if there is Premium on the way into the city? I hope to fill up in Alabama before crossing the state line and have enough gas to last me until Friday when I leave.
Tom Hutchinson
Old 09-29-2008, 05:22 PM
