mnmasotto's Avatar
Need 12V switched source in the eng. compartment
I have a 1987 Carrera. I just installed a MAF which requires a 12V power source. I need a source which is switchable (only hot when the key is on) I found a 12V source using either of the three fuses on the posterior, left side of the engine compartment. However, these are hot all the time. I find the MAF draining power while the car is sitting.
Need help, Thanks
1987 Carrera MoTec 3.8L Transplant, 993TT Brakes
2006 M3 Competition Package
2007 997 GT3 - SOLD
Old 09-30-2008, 09:33 PM
I needed a 12v switched source when I installed a shift light a while back. I ended up pulling it from the fuse panel up front. I realize that is from the wrong end of the car but it may save some time and frustration if you have not solved the problem yet.
Good Luck~
85' 911 Coupe: Rebuild complete.
Old 10-01-2008, 08:57 AM
TroyGT's Avatar
The heater blower fan only works when the key is hot.
-Troy
1986 911 Coupe (Guards Red), Fabspeed Euro Pre-muffler,
Steve Wong Performance Chip
2001 Boxster 2.7L (Orient Red), bone stock
Old 10-01-2008, 09:12 AM
