I split my nuts!
In getting ready for my MK cat bypass and Steve Wong chip I had 4 nuts on my cat that would not come off. I purchased the 1 1/2 inch cutoff wheel for the Dremel and went at it. In only 15 minutes all were off. This amazing bit went thru the nut and bolt like it was butter. I am not easily impressed but this cutoff wheel is highly recommended. I used the dremel at its highest speed of 30,000 rpm.
"The smaller the fine print, the larger the risk." 1988 911 coupe 2008 VW R32 2004 530I |
Good to know! I have to do that soon.
Babak |
Gary H 1978 911 SC
I thought this was about a medical issue.
That is exactly how I took mine off.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Manassas, VA
What will you use for replacement bolts? I am assuming the MK cat bypass (for testing purposes only) does not come with the flange hardware.
Thanks, Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Hardware is available from SW chips also. All stainless and a small amount of anti seize. gaskets also.
