Targa seal at windshield help
Need some advice: I am about to install my new seal. In doing a "dry fit" found it to be very tight to get seal into groove. How is is going to be any easier with adhesive? Can I line the groove with adhesive and still install the seal with a soap water lubricant? Any tips, tricks or advice will be highly appreciated.
thanks,
Bill
Old 10-03-2008, 10:15 AM
scottb's Avatar
What year is your car? Are you certain you have the correct seal? I don't recall the details, but for some years the correct seals are NLA, and you either have to get an aftermarket seal or modify the factory seal for later year cars.
The "guru" for all things related to Targa tops (including seals) is Dan Pechtel. www.carsinc-nj.com. You might give him a call to determine if you have the correct seal. If you do, I'm sure he'll give you some advice on installing the seal.
HTH.
Scott
1984 Targa
Old 10-03-2008, 12:02 PM
yep, it is the correct seal purchased from Dan. I need to know if I can coat the groove with adhesive and still have the seal somewhat lubricated with a soap/water solution to get it to slip into place. my fear is getting stuck, and not being able to get it to the final correct position.
any tips, or advice welcome
thanks,
Bill
Old 10-03-2008, 12:58 PM
carreraken's Avatar
subrscribed, I also have the seal from Dan waiting to be installed...
Ken
06 Cayman S - gone
85 911 Targa - gone back home to Germany
73.5 911T Targa - long gone...
Founder ncPOG: nevada county Porsche Owners Group - disbanded post covid after 15 yrs
Old 10-03-2008, 01:21 PM
Member 911 Anonymous
DRACO A5OG's Avatar
I got the same front seal from Dan.
I did not use adhesive at all and after 6 months or so no issues.
I simply sprayed the area with water for lubrication and slid it in and adjusted where it needed. I figured once dry it should self seal. You will notice grooves and ridges on the new seal to help keep it in place.
Per shop manual, I started with the two corners, down the pilar then finished at the top center. Just pressed it in.
Note, make certain that ends line up with the door & quarter window and that you do not see, day light, if you do you will get wind noise.
My plan was to use adhesive once the seal sits and forms but to date found I did not need to glue it down. Yes, I drive with the top off and the seal sits perfectly in place. Dan's seal is right on the money.
Jim
'85 Carrera Targa
PCA/POC
Old 10-03-2008, 03:29 PM
apprentice restorator
darshie76's Avatar
I've got recently both seals for the targa (except the 2 on the side...ironically the part where the gap is bigger and the water comes in)
I've had a lot of issue to put the new one in (the rear one, so the one that sits on the targa bar), and is not even glued, but looks ok, except that i noticed that the seal stops at the end of the rollbar, while the old seal that i had, was going all the way down the sides of the doors, so i had to cut it and now seems pretty good.
Now my question is: what would be the correct procedure to get the seals right ? (tomorrow i start with the front one , after gluing the back one) because after spending 400 dollars for the seals would be not nice to stick the glue in and have issues :P
I see here that you should lubricate the seal? I simply pulled out of the bag and sticked in place....is that wrong? (probably yes, since some water was coming in while i was washing my baby to check for other weak seals )
Now i empathize with people that works in body shops...is a crappy job to put seals on took me 3 hours to clean up the area where i will put the glue and the seal; and tomorrow i gotta start all over since i have to remove the seal and put the glue and then put it back
Old 10-19-2008, 12:34 AM
Paul K's Avatar
Just got my seal from Dan. What kind of glue are you guys using?
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 11-12-2008, 05:35 PM
DRACO A5OG's Avatar
I have the black 3M adhesive but yet use it. I used a spray water bottle to wet the surface of the frame then slid the seal on per manual. It's been about 6 months and no glue needed.
'85 Carrera Targa
PCA/POC
Old 11-12-2008, 06:55 PM
slodave's Avatar
Jim, you live where it does not rain. My seal is not glued either, but I would have, if living in a wet climate.
Old 11-12-2008, 07:09 PM
Paradigm Short Shifter
Send a message via AIM to UrQuattro Send a message via Yahoo to UrQuattro
Sorry to bring this thread out from the dead guys, but the black 3M adhesive referenced above... That isn't the black tarry stuff that comes in a roll and is like putty, is it? Or is there another glue that has the consistency of glue or caulking c
I'm trying to work up the courage to install the front targa seal that I got from dan about 6 months ago. I'm having bad luck with working on my car recently.
thanks in advance
Michael
Old 10-05-2010, 06:47 AM
scottb's Avatar
Originally Posted by UrQuattro View Post
Sorry to bring this thread out from the dead guys, but the black 3M adhesive referenced above... That isn't the black tarry stuff that comes in a roll and is like putty, is it? Or is there another glue that has the consistency of glue or caulking?
If it's the stuff I'm thinking of, it's essentially glue in a tube that you can get at your local Autozone, Pep Boys, etc. But, if you're unsure, call Dan. He'll tell you what to use.
Good luck!
1984 Targa
Old 10-05-2010, 07:49 AM
DRACO A5OG's Avatar
Heck, I did not use glue at all, because the new seal seated perfectly.
I did use a water spray bottle to make it easier to slide the seal in. It has been over a year and now the seal has not slipped off even when on the freeway at high speeds with the top off.
Thanks Dan the man!
'85 Carrera Targa
PCA/POC
Old 10-05-2010, 09:01 AM
Weekend Mechanic
vulcan300's Avatar
Hey Jim,
I've got one of those seals on order. When I remove the factory seal this weekend I found that it was held in with a generous helping of contact cement. I've spent a lot of time cleaning out the contact cement and would love to avoid gluing the seal in. Have you had any water intrusion when washing the car or driving in the rain?
86 911 Carrera Targa
Old 10-05-2010, 01:11 PM
DRACO A5OG's Avatar
Nope, super tight, in fact I had to remove all the old glue so Dan's seal could fit correctly.
'85 Carrera Targa
PCA/POC
Old 10-05-2010, 01:34 PM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
def watching this one
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 10-05-2010, 02:38 PM
I used just a very light coating of glue. Maybe you can get away without gluing over the windshield , but down the window frames it needs glue. 3M or Wurth.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-05-2010, 02:43 PM
Senior Member
Jdub's Avatar
About to take on this task, but Dan's seal on the front and for the rear the Porsche seal ($$$!!!) as well.
I typically use Ru-Glyde for seal installation where glue is not required. In this case, esp. for Dan's seal, I would surgically clean the channels and fit the seal using both the slippery agent and a hot day to aid flexibility in the work.
My question to the forum is has anyone tried installing the seal without glue, set the Targa top on to the seal, then taken the car for a spin to check the sealing? Even watered the area for leaks? My approach is to test fit without glue and conform the seal before removing it and finishing with glue. Thanks in advance for your advice much appreciated!
'78 Targa in Minerva Blue
Old 06-14-2025, 09:35 AM
