krd krd is offline
krd's Avatar
what is this light?
the title says it all?
1988 porsche 911 "CE" cabriolet
Old 10-04-2008, 08:25 PM
frankc's Avatar
At first I thought it was an EGR light, but that would be between the tach & speedo, and 88 Carreras (based on sig) did not have EGR. So, sorry - no help.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 10-04-2008, 09:12 PM
Oxygen sensor. Every 20K (or 30K?) miles, it automatically turns on. If you still have an O2 sensor, it might need to checked out. There is a small reset button on the back of the speedo near the odometer that will reset the light for 20K more miles.
EDIT: At least for an SC...I assume a Carrera is the same...
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-04-2008, 09:17 PM
Senior Advisor
James Brown's Avatar
that's the "steering wheel removed" warning light, it wil go out when you put the wheel back on.
08 Cayenne Turbo
Wandered off somewhere...
Drdogface's Avatar
That's FUNNY !!
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 10-04-2008, 09:30 PM
crustychief's Avatar
I thought the newer-than-mine cars had temp gauges that read in degrees instead of the blank bars?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 10-04-2008, 10:05 PM
Member 911 Anonymous
DRACO A5OG's Avatar
This was posted before, it is an "Emission Control" EX light connected to your O2 Sensor
According to PAG those were installed on exports to Japan indicated by "J"? Is that right?
'85 Carrera Targa
PCA/POC
Old 10-04-2008, 10:47 PM
krd krd is offline
krd's Avatar
thanks for the input. you should stick to music though! oh, i forgot your dead.
it's not an export. i will check the o2 sensor reset. if this isn't it, the PO had some kind of funky alarm installed which i removed. thanks.
Old 10-05-2008, 04:29 AM
Somatic Negative Optimist
Gunter's Avatar
Posting the year/type would help a lot to avoid guessing.
Yes on the OX sensor light.
Or oil dip stick is missing?
Ash tray open?
But, it could also be a warning that the ejection seat is primed.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 10-05-2008, 08:40 AM
the the is offline
It's an aftermarket alarm light.
Old 10-05-2008, 09:27 AM
Az911's Avatar
Send a message via AIM to Az911
I was going to say the same thing since my 88 doesn't have that light.
72T RS look
96 993
Old 10-05-2008, 09:43 AM
3.2 CAB's Avatar
That light, between the tach and the oil temp and pressure gauge, on a 1988 cabriolet, is the Cabrio Top Warning Light. The O2 sensor light, used up to 83, would have been between the speedo and the tach. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-05-2008, 10:41 AM
No, earlier cars have "real" (numbered) temperature gauges and oil pressure gauges that read to 140 PSI.
'77 S with '78 930 power and a few other things.
Old 10-05-2008, 12:01 PM
Senior Advisor
Hey KRD, check if the top is down!!!!
08 Cayenne Turbo
Old 10-05-2008, 12:54 PM
Thanks for correcting me . I couldn't remember if the OSX light was just to the right or left of the tach, and (strangely) my car wasn't sitting in my lap when I posted
Mike Bradshaw
Old 10-05-2008, 08:28 PM
the the is offline
yep, didn't notice your car is a cab. I had an 88 cab, too. that is correct. Yours is missing the red lens, though.
Old 10-05-2008, 08:33 PM
