One or Two Brake Light Swiches???
As I posted earlier my brake lites went kaput. I was going to order a new switch, the web page here at Pelican Parts says two are required. I see only one mounted to the master cylinder. What am I missing? The car is a '82 SC.
Old 10-08-2008, 02:07 PM
pa911's Avatar
I think it should be two
Old 10-08-2008, 02:53 PM
rnln's Avatar
there are 2. Becareful with the fluid. You should read this.
Brake Lights
Fat butt 911, 1987
Old 10-08-2008, 03:07 PM
Yup, I have two switches and the aft one looks like a SOB to reach. I'm going to try the relay mod. Thanks for the help.
Swen
Old 10-08-2008, 03:32 PM
rnln's Avatar
I used a long socket, and not too big rachet head.
Fat butt 911, 1987
Old 10-08-2008, 03:47 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Hey Swen,
Get a helper to press down on the brake pedal when you replace the BLS's so you will not introduce air into the system. I would also place new fluid into the new BLS before installing.
Jim
BTW where are yo located?
'85 Carrera Targa
PCA/POC
Old 10-08-2008, 04:32 PM
myamoto1's Avatar
I'd also recommed getting Jim's (DRACO A5OG) BLSAS relay kit. Just installed mine today and hearing that relay click when I step on the brakes, gives me 2 levels of confidence: 1) I know my brake lights are on and 2) I know I won't have to replace my BLS any time soon. Easy install and great company/guy to deal with. Thanks again Jim!
Josh
85 M491 Coupe - "Fat Bastard"
Old 10-08-2008, 10:10 PM
Insane Dutchman
I'd add support for the BLSAS relay kit...fairly easy install....should never have to do it again.
Dennis
1975 911S with Kremer 3.2
1989 911 Carrera Project Car
Old 10-09-2008, 12:42 AM
emac's Avatar
Dont want to start anything here but you do not have to step on the brake pedal when you install the new switch. In my case and more then once, I had everything out of the way and ready. Removed old switch and replaced. Actually never had to bleed the brakes.
Just my 2c
Ernie 81 SC
Old 10-09-2008, 07:01 AM
3.2 CAB's Avatar
If someone does more than just very minor pressure on the brake pedal, while the switch is removed, there will be brake fluid everywhere. You don't want someone that is just going to press on the pedal, thinking to do the same as they normally would for using the brakes. I have changed many master cylinder mounted, brake light switches over the years, on various makes and models, but I never had anyone press on the brake pedal while doing so.
If you really want to try to ensure the least amount of air entering the system during a switch change, you can pre-load the new switch with a couple of drops of fresh brake fluid with an eye dropper, or like instrument. Then remove old switch, and replace with the new switch. Be sure to wipe all of the dirt, grit-n-grime from around the fitting area, before removing the old switch, and wipe clean the fitting, before inserting the new switch into the threads. There may be a drop or two of brake fluid seep from the switch mounting hole, but it won't be a problem a paper towel or shop rag can't control. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-09-2008, 10:03 AM
emac's Avatar
Tony
Ditto---when I removed mine the M/C weeped a few drops of fluid which in my opinion would not allow air in. After the install all I did was check and top off a little. I didn't get into the detail you did but you hit it on the head.
Ernie 81 SC
Old 10-09-2008, 10:09 AM
gtc gtc is online now
abides.
gtc's Avatar
+1 Ernie, this isn't as hard as people are making it sound. I didn't bleed mine afterwards, and the brake feel was unchanged.
Graham
1984 Carrera Targa
Old 10-09-2008, 10:21 AM
emac's Avatar
Graham
Your right, as I remember it took me no longer then fifteen to twenty minutes to install both switches, and that included removing the duct work. In my opinion the biggest part is getting the proper tools ready a rag etc and finding some way to get you body in the proper position to lay in the trunk!
Ernie 81 SC
Old 10-09-2008, 10:25 AM
rnln's Avatar
My last more less 4 months now. They usually last best only 2 months or so. I used to have to replace the switches several times a year, until I couldn't keep up with them any more. His last almost a year now if I remember correctly.
Fat butt 911, 1987
Old 10-14-2008, 12:41 PM
