UNDER CONSTRUCTION!
carrera turbo's Avatar
what year 915 is this and anyway to figure gear ratio?
here is the number wondering what it maybe im needing one and this is one i found.
"915.301.102.3P"
915.301.101.7R
these are the two numbers on the case
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 10-11-2008, 06:20 PM
I'd say those are casting numbers for the case. The type number is stamped on the very bottom and will be something like 915/06 (ie: the /06 is for a 1974 911). That type number will be a start to re-ask your question so you can get the stock gear ratio's for the box you have.
edit: check this thread for the photo and additional info on limited slip number (12).
Option code for LSD in a 915?
Tony G
2000 Boxster S
Old 10-11-2008, 06:51 PM
UNDER CONSTRUCTION!
thanks im looking at a tranny on e-bay and this is the only numbers i have so far thanks for your help ill get back to this post when seller gets back to me with the numbers
thanks ed 916/02
Old 10-11-2008, 07:05 PM
UNDER CONSTRUCTION!
bump for new number 916/02
Old 10-14-2008, 11:54 AM
UNDER CONSTRUCTION!
pics
Old 10-14-2008, 11:57 AM
KTL KTL is online now
Schleprock
KTL's Avatar
That's 915/02
1st gear = 11:35 = 3.182
2nd gear = 18:33 = 1.833
3rd gear = 23:29 = 1.261
4th gear = 26:25 = 0.962
5th gear = 29:22 = 0.759
the other available ratios were
4th gear = 27:25 = 0.926
5th gear = 29:21 = 0.724
Kevin L
'86 Carrera "Larry"
Old 10-14-2008, 12:52 PM
AutoBahned
RWebb's Avatar
do a search for things to avoid re 915 trans. models
there is a huge thread on it
Old 10-14-2008, 01:51 PM
Grady Clay's Avatar
My eye says that is a 916/02.
If so, that is a VERY RARE and valuable transmission for the 1972 Porsche 916 - the 2.4 MFI 914-6 with a 915 adapted for mid-engine configuration.
Are there any other pictures?
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 10-14-2008, 08:44 PM
Schleprock
KTL's Avatar
I even went to the trouble of flipping that picture over and still think it's possible that the third digit is a 5. It's so marred, it's hard to tell. The guy says it's on ebay, so a link would help a ton!
Kevin L
'86 Carrera "Larry"
Old 10-15-2008, 10:15 AM
Schleprock
KTL's Avatar
Kevin L
'86 Carrera "Larry"
Old 10-15-2008, 10:17 AM
UNDER CONSTRUCTION!
Originally Posted by KTL View Post
this pic is from the owner he sent me through private e-mail and he said in person it is a 5 not a 6.
this is a tranny i was thinking of buying for a race project i have and my low H.P. of my 3.0 might enjoy these low ratios. did a search on here and would do some improvemnts if i go this route.
thanks ed
Old 10-15-2008, 11:08 AM
