MFI Injectors
I have a 72 911T 2.4 MFI. It's running great but I'm chasing down the last few performance gremlins. I was experiencing a mixture problem in that it was easy to start and gradually ran rougher as it warmed up. I disassembled the thermostat and gave it a good cleaning and test. After reassembly, it's now rather hard to start but runs MUCH BETTER at temp.
As it stands now, I think I'm still a bit rich. I get the occasional exhaust backfire on deccelleration but nothing like before the cleaning of the thermostat. So, going through the CMA, 1) Air cleaner cartridge - new 2) Compression loss - still chasing down a tester 3) Spark plugs (spark plug connectors) - new 4) Dwell angle - set 5) Ignition timing - set 6) Fuel pressure and flow - OK I'm stuck on determining if my injectors are good. I can't seem to find used spares or anyplace that has the ability to test them. At $180 a pop, a new set is not an option. Anyone know of a place to get my injectors checked? Anyone have a few spares sitting around? 901-110-271-00-M14? Help? Last edited by tharbert; 10-13-2008 at 08:25 AM.. Reason: Apparently, <<Ctrl>> V meant "Post" to my browser window... |
From what I have read, and having mine tested by Gus at Pacific fuel injection is that they rarely go bad because they are mechanical. Call Gus and ship them to him.
72 911 Although it is done at the moment, it will never be finished. |
Thread Tools | |
Rate This Thread | |
