'78 930 with non-floating front rotors?
I am not crystal clear on all the different versions of brakes that were offered on 930s from '76 to '89 but I was quite sure that a '78 ROW car should have floating (2 piece) front rotors. Take a look at these pics and please help me out. These are obviously one-piece non-floating front rotors. Are these rotors a direct replacement for the floating rotors?
Old 10-13-2008, 08:56 PM
I hate freight charges
village idiot's Avatar
Send a message via Yahoo to village idiot
Don't know about the calipers, but it looks like the p.o. either lost or damaged the grease cap and that was his solution. Looks like you would thread a bolt into the cap to have leverage to remove it.
Tom
Tom
78 911SC SC to 73RS imposter SCWDP crew #50 and 51
1969 Camaro "The new project"
Old 10-13-2008, 09:25 PM
cl8ton's Avatar
I think your 78 floating rotors were installed on my 87 930 by a previous owner j/k
Trust me, the cost of 2 piece rotors are insane! Ask me how I know?
You are correct, you should have floating rotors on that car.
To go back to 2-piece rotors, you will need to find:
Dog eared hats, rotors and new hubs.
The welding on the hub center cap is standard for 1 piece rotors from the factory
If you’re looking for 1 piece front rotors, PM me as I bought a set by accident a while back.
Here is what my back dated 930 front braking looks like.
Rod...
2010 - 997 PDK, Black on Black, Daily driver.
1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony!
Old 10-13-2008, 10:14 PM
Originally Posted by Ringmaster View Post
I am not crystal clear on all the different versions of brakes that were offered on 930s from '76 to '89 but I was quite sure that a '78 ROW car should have floating (2 piece) front rotors. Take a look at these pics and please help me out. These are obviously one-piece non-floating front rotors. Are these rotors a direct replacement for the floating rotors? Is this still the original '78 caliper pictured? What about the hub?
Assuming these one-piece front rotors are a bit worn, what are my options to get 2pc front rotors back on the car?
It looks like somebody converted the car to the '80-on 930 hubs and one-piece rotors due to cost reasons. Those are the early '78-'79 930 calipers.
If you wanted the lighter 2-piece ones, you would need a pair of 911 hubs, front 930 wheel spacers, and a pair of early 930 rotor/hat assemblies. One can use the early full-floating ones (very expensive) or one of several aftermarket 2-piece rotor/hat options; some of which are VERY good.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-14-2008, 12:43 AM
Bill Verburg's Avatar
There was a TSB that was issued in '80 with regard to that, so most 930s that were dealer serviced and need new fronts would have gotten the treatment that yours has gotten.
Unless you are racing there is nothing really bad about that set up.
Bill Verburg
Old 10-14-2008, 04:47 AM
Steve, What are the options now? I bought some rotors from you years ago for my Carrera with the 930 brake conversion from VCI and have been very happy, but they are in need of replacement soon. I think the one you sold were modified Brembo's cut down to fit. Still the same ones?
Old 10-14-2008, 05:12 AM
Yessir,...that what we use,..
They have been VERY durable in all of our race cars over the past 6 years. All you will need is the rotors, not the hats.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-14-2008, 09:19 AM
For a street and track combo 930 my guess is the floating rotors don't offer much real world measurable benefit. If I could buy nice 2pc front discs to work with my current (incorrect) hubs for under $400ea I would do it, otherwise I will say with the '80> 1pc discs.
Old 10-14-2008, 08:11 PM
You'll not find any decent 2-piece rotor/hat assemblies for that kind of money although ours (flat-hat style) are close.
My best advice would be to retain what you have due to reasonable cost unless you need lowest possible unsprung weight.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-14-2008, 08:16 PM
