SCWDP911's Avatar
Very weird no spark condition
Another pelican buddy here locally is having a really weird no spark condition in his SC. I think his is an 82 or 83 with a pretty-much stock 3.0. Here is the deal:
He can start the car up and runs fine for 10 minutes, and then, cuts out and no spark until later. I am not sure how much later, but in our conversation about it, it sounds like if y ou went out to the car every morning, it does the exact same thing, starts, runs fine for 10 minutes, and then dead.
He has checked most of the ignition system out with the exception of detailed check of the distributor. He has replaced the green wire, changed to an MSD system, new coil. Any ideas?
He is going to post sometime as well, but I have been thinking about his dilemma all morning...
Shane
- 1984 928S
Old 10-19-2008, 08:22 AM
SCWDP911's Avatar
darn, no takers yet?
Shane
- 1984 928S
Old 10-19-2008, 07:45 PM
RS 73
Check the grounds everywhere. I had a loose ground give me similar intemittent problems like this.
Dick Lague
RGruppe #79
1973 RS Spec Carrera
2001 Saab 95 Aero
2003 Saab 95 Aero
Old 10-19-2008, 09:08 PM
jtfreels's Avatar
Thanks for thinking of me Shane
I did start a thread here my SC starts fine, but I can't keep it running, doesn't seem like the usual problem.
I'm thinking this is down to the distributor some how. Magnetic pickup ring?
Jay
2002 Boxster Speed Yellow
Old 10-20-2008, 06:30 AM
Smart quod bastardus
fredmeister's Avatar
He needs to make sure it is spark related when the problem is happening. Tell him to remove a spark wire lead and ground it to engine block to see if he is getting spark while cranking when the issue is occuring. Otherwise it may be fuel pump related. They go bad or the relays fail and quite possibly it works when fuel pump or relay is cold but then fails as it warms up from useage.
Good luck.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-20-2008, 06:50 AM
