(the shotguns)
berettafan's Avatar
pulled accelerator pump stud on webers...
Trying to track down a sudden popping/spitting through the exhaust issue after todays autocross and noticed one of my accelerator pumps leaks via the top when actuated.
i find that one of the top nuts seems to just spin the stud and never tightens. whats the fix for this? jb weld or something like that? i've never used the stuff but seems like this would be a nice place to use it. the nuts are quite small and i don't believe pressures put on them are much.
i need to fix this issue before i go back through the carbs to track down this new spitting/popping nonsense. appreciate any ideas.
Old 10-19-2008, 07:15 PM
abit off center
cgarr's Avatar
You can either buy or make a repair stud, its the next size larger on the end to be repaired and same size as the nut side. Used in exhaust stud repair quite often.
______________________
Craig
G2Performance
Old 10-19-2008, 07:20 PM
resurface the cover while you're at it. they're usually warped. maybe the nut itself is stripped?
206 637 4071
Old 10-19-2008, 07:41 PM
(the shotguns)
berettafan's Avatar
thanks guys. i did resurface both covers when i 'rebuilt' the carbs.
ya know it is entirely possible that the nut itself is stripped.....that would be awful nice!!!
Old 10-20-2008, 05:49 AM
(the shotguns)
berettafan's Avatar
aha, the NUT is stripped!!!
anyone happen to know the size so i can pick it up at the hardware store vs. ordering from pierce, etc.?
Old 10-21-2008, 10:37 AM
3.2 CAB's Avatar
You dodged the bullet on that one. I don't recall the size, just take one of the good ones with you to match it up. Good luck!! Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-21-2008, 11:02 AM
4mm. smaller than the carb top nuts, which are 5mm.
206 637 4071
Old 10-21-2008, 11:13 AM
(the shotguns)
berettafan's Avatar
dumb question here; are all 4mm nuts the same pitch?
Old 10-21-2008, 11:28 AM
