idc1873
coxy's Avatar
G50 clutch
Anyone know the wear limit on a G50 clutch centre plate & what is the plate thickness when new.
Old 11-04-2008, 01:54 AM
MBEngineering's Avatar
HI coxy
Hear you go!!
for educational purposes only!
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 11-04-2008, 05:59 AM
idc1873
coxy's Avatar
Originally Posted by MBEngineering View Post
HI coxy
Hear you go!!
regards mike
Brilliant mike thanks, droped the engine at the weekend, clutch plate @ 9.5mm so A ok.
Old 11-04-2008, 06:25 AM
Anyone have the same specs on a Turbo Clutch? The PO of my car went with the turbo model and I think it's still well in spec but I'd like to confirm.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-04-2008, 08:07 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Unless someone has the exact spec for the Turbo clutch disc, i'd use the same specs for G50 disc. Figure based upon the tech information shown, you can expect ~ 1mm thickness of lining material above the rivets. Put a depth gauge into you clutch disc and see how much you've got above the rivets, since the rivets are typically a "gauge" for replacement- if you're wearing on the rivets, time to replace clutch disc.
Kevin L
'86 Carrera "Larry"
Old 11-04-2008, 11:06 AM
Kevin, thanks, that makes sense. I've got quite a ways to go before I hit the rivets, IIRC.
Buck
'88 Coupe, '87 Cab,
Old 11-04-2008, 12:33 PM
