Follow me
Dumb question please help!
I backed my car up on some ramps. Now I need to jack the front up and put floor jacks under it but every place I start to jack bends a little so I stop. Were do I place the jack so I don't damage anything? Thanks I know Im going to hit myself.
1982 911SC |
(the shotguns)
i use a floor jack and piece of wood under the front pan to spread the load. however my car doesn't have a/c so pan section is relatively flat. not sure that's the case on yours.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
(the shotguns)
btw why do you need both ends in the air?
Follow me
Front pan? Im in the prosess of taking out my AC and Im doing a heater backdate.
1982 911SC |
I sometimes put a stick of wood, 2x2x~18" across the front of the pan just behind the front condensor. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Follow me
Got it! Thanks alot Ken
1982 911SC |
