Designer King
Paulporsche's Avatar
Advance Wrong--What to look for?
A mechanic who was recently working on my car said I am getting full advance @ 2000 rpm. I understand this should not happen until about 3500 to 4000.
If I open up the diz what should I be looking for? Broken springs? Dislocated weights?
I should be able to see a broken spring or a weight that has come loose. What else could cause this? Can I tell by look or feel if something is worn or fatigued?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-31-2008, 02:14 PM
Paul,
You should look for a broken or missing spring on one of the weights.
Remember, there are two springs in these things: one is a light spring and the other is stiffer. Both are required for proper operation.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-31-2008, 02:44 PM
Designer King
Thanks, Steve.
If springs are intact, is there anything else that could cause this?
Is there any reason why someone would deliberately ramp up the advance this quickly?
Paul
Old 10-31-2008, 08:11 PM
moneymanager's Avatar
Not if his brain was intact!
jhtaylor
santa barbara
74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's.
73 Targa (gone but not forgotten)
Old 10-31-2008, 08:48 PM
Originally Posted by Paulporsche View Post
Thanks, Steve.
Either someone put in a very aggressive advance curve, or the weights may be stuck,........
Sounds time to remove the distributor and disassemble it to clean it up and make certain that its working properly. The latter aspect should be done on a distributor machine.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-31-2008, 11:19 PM
polarity backwards on MSD? done that once or twice with the same results
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-01-2008, 04:41 AM
Designer King
moneymanager,
LOL! Can never rule that out.
Steve,
Thanks again.
Ben,
Interesting. I thought I read somewhere that there can sometimes be issues between MSDs
and the dizzies, but I couldn't remember what they were. I'll have to check out the polarity. Thanks.
Paul
Old 11-01-2008, 05:35 AM
[QUOTE=Paulporsche;4273744]A mechanic who was recently working on my car said I am getting full advance @ 2000 rpm. QUOTE]
As long as it does not ping, consider yourself lucky. All in at 2k will enhance low end torque and throttle response.
Old 11-01-2008, 06:37 AM
Designer King
stlrj,
You might be on to something. This setup was prepared by Rudy Bartling (Google him if you don't know who he is; kind of an older Grady Clay w/ a German accent!) who's been working on these cars since the late 50s. I've been using it for something like 17 years w/o problems. The MSD has been on for 3 years. My mech said he found no broken springs.
Ben,
When you say you had the same results, you mean that polarity made no difference to the advance curve?
Paul
Old 11-01-2008, 07:27 AM
Paul,
If the polarity of the wires that trigger the MSD unit is reversed, the advance curve is about 15degrees off.
This is a common occurance so its something to check.
The green coaxial distributor trigger wire should be connected as follows: center conductor to green MSD wire & violet MSD wire to the shield.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-01-2008, 09:15 AM
That far retarded would have been noticed by your mechanic since your engine would barely idle if it started at all.
Old 11-01-2008, 11:51 AM
stlrj,
Ben,
no I had way to much advance at low rpm all do to polarity
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-01-2008, 01:36 PM
