tedder's Avatar
Cat - What is this screw for ?
So I had to put the cat back on the car (now required for inspection every year, sigh). The exhaust had gained an annoying whistle, and on inspection, I noticed that there seems to be a bolt missing from this hole in the cat (before the core). The pic is of another cat btw.
So, the questions are;
1. What size/type of bolt can I stick in here to plug it (nothing I have on hand seems to fit)
2. What the heck is this bolt here for?
08 Porsche Cayman (base) <- My hands are too big to need to compensate with an S
86 911 Coupe <- WOOT <- sadly gone since late 2014
Old 10-27-2008, 04:23 PM
Oh Haha's Avatar
For attaching the heat shield, maybe?
Remember those threads are metric. Either take it down to the local hardware store and trial fit until you find one or find one close and rethread it using a socket wrench on the bolt.
Pacific Blue
Wayne
Old 10-27-2008, 04:27 PM
Virginia Rocks!
VaSteve's Avatar
That's the test bung, hence why it's in front of the core.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 10-27-2008, 04:59 PM
rnln's Avatar
if you take it off, you will see your rpm jump lot quicker
Fat butt 911, 1987
Old 10-27-2008, 05:10 PM
You remove it and install a CO reader for testing purpose. It is so rusted now it will just snaps off if you even breath on it.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 10-27-2008, 07:23 PM
tedder's Avatar
Any idea what size it is? a 1/4" bolt slides in easily so I am guessing 7-9mm. Should i worry about what kind of metal I use for the bolt I stick in there? I don't like the idea of exhaust pointing straight at the tire (plus the whistle is annoying)
Old 10-28-2008, 03:05 AM
Slumlord
Porsche_monkey's Avatar
If a 1/4" bolt goes inside it is likely M8. And it probably needs re-tapping. Then put in a stainless steel bolt with anti-seize.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 10-28-2008, 06:56 AM
As I remember from somewhere it is the same thread as a spark plug. I may be thinking of the O2 sensor.
Old 10-28-2008, 06:59 AM
