(the shotguns)
Clicking sound in reverse
Car makes a clicking sound when moving in reverse however ONLY when reverse gear is engaged. in neutral rolling backwards there is no sound.
Anybody experience this and if so how long do i have before i'm learning about 915's?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Designer King
CV joint?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
(the shotguns)
btw, i can have the clutch IN and so long as the lever is in 'r' it clicks when rolling backwards.
Paul, if CV wouldn't the car make the sound regardless of gear shift position?
i would still lean towards the CV.
condition of boots? miles on CV's
Designer King
Berettafan,
I don't know for sure. I was thinking it would only occur under load. I hope for your sake it isn't a transmission bearing. Can you try to isolate where it's coming from? One side or another, for example.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 10-28-2008 at 11:01 AM.. |
