Member 911 Anonymous
Hey Fellas,
Does anyone happen to know the length of the hard brake line coming from the MC to the elbow in front of the tunnel, NLA part # is 911 355 607 03 ![]() It looks like I need to build one ![]() ![]() TIA, Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
French Import
Jim, I can measure mine when I get home this evening.
Buzz me if you don't hear from me before 9:00pm.
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Oh My Brother G,
I really appreciate it, no hurry, my brakes didn't feel that bad right? Well I need to investigate at the top of the MC to insure it is not weeping from that end either. Well it looks like a visit to Napa. I did my caliper hard brake lines, so I guess it is time for this one ![]() J
French Import
Oh good, I am by myself this evening and need another hand to hold the flashlight...
I'll figure it out and give you the dim.
Diss Member
You have the wrong part number and the wrong diagram there. That diagram is for an SC and a turbo. The Carrera has 2 lines and a proportioning valve in that section of the rear system.
The section you are looking for is pn #91135507900. (#13 on the diagram) ![]() If you need it #10 is pn #91135507700 #9 is only on this diagram as the alternative for the turbos.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Diss Member
Oh and the proportioning valve (#12 and #11) is under a piece of fiber board between the MC and the smuggler box.
Strrange, but as in my pic do you see that elbow, I don't see #10 going into an elbow.
Diss Member
#13 is the one that connects to the elbow. They just don't show the elbow.
I'm going to give you a call in a bit about the parts books.
PMed you
The trick is how the heck does one fish it thru with that freakin 45 degree bend or if it 1 #13 just straight up to the proportioning valve???
Update: 2 days of driving and slamming the brakes at stops. Attempted to tighten that fitting.
Well it appears to be dry, but still want to replace it: ![]() Now to bleed the brakes once more
