Upgraded DME to 4k for SW Chip. Stock chip work?
Hello, fast question for the SW guys. I SW chipped my car a while back along with my cat/bypass sport muffler upgrade. I have to bring my car to inspection, and put back on the catalytic converter. I dont feel like going back to the DMV twice, and i've heard sometimes people fail with the SW chip. Can i install the stock chip back in even though i upgraded the dme with the jumper to make it read the 4k chip? Or do i need to reverse this mod?
1984 Porsche Carrera Cabriolet - sold, regrettably
2003 Toyota Matrix - VVT @ 6K FUN - sold, not regrettably
2005 Mercedes C230 Kompressor Sport Sedan - now...
Old 11-19-2008, 06:43 AM
Contact Steve.
I belive he told me the jumper mod is of no issue and some DME's already have that mod from the factory.
Old 11-19-2008, 07:40 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
No need to reverse to 2K.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 11-19-2008, 09:18 AM
slodave's Avatar
Not totally true. Early DME's, like mine, can't be upgraded and still run the old 2k chip.
Old 11-19-2008, 11:57 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
OK...mine is an early one...and upgraded.(((All 84-86 911s can upgrade to the later 4K program by a simple jumper move and readjustment of the base idle speed. After you make this mod you can still run your old chip without changing the jumper back.))) This one directly from Steve web site.
<IN GAS WE TRUST>
Old 11-19-2008, 01:43 PM
slodave's Avatar
I talked with Steve about this as well. Certain early DME's can't be upgraded to a 4K, and then run a 2k. I tried, it didn't work. Steve then remembered and confirmed that it does not work on the early 84's. I believe chips numbered 1267355028 (mine is) can't run on an upgraded 4k DME. To make it worse, I also upgraded to a 28 pin socket and the 8k chip. You really can't go back and use the 26 pin 2k chip.
Again, not all 84's can upgrade to 4k and then switch back to the 2k chip.
Old 11-19-2008, 05:36 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Talk to Steve, I purchased a Stock Chip from him for my updated DME.
'85 Carrera Targa
PCA/POC
Old 11-20-2008, 09:04 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Interesting.....I'm curious and want to know more about it...What's happened when you tried to come back at 2K.....dead engine...?
<IN GAS WE TRUST>
Boy does this suck. Guess i'll have to clip the jumper and resolder it after inspection. Whats the worst case scenario if i swap the chips without reverting back? Will my car blow up or will it just not start and everything will be fine once i revert back? I'm tempted to solder in pins in place so i can pop on and off a hard drive jumper.
Old 11-20-2008, 09:15 AM
DRACO A5OG's Avatar
Call Steve, he'll take care of you.
'85 Carrera Targa
PCA/POC
Old 11-20-2008, 09:28 AM
