sbrown.nw's Avatar
Mirage Intl bump steer kit
Anyone used this item on their cars bump steer kit at bottom of page? Any idea how much it costs and are the more expensive kits that much better than the bolt and spacer kits?
I had a 78 911 SC Targa that was lowered to Euro height without turbo tie rods in the front and it made a difference when I installed some rack spacers (bolts and washers). I am thinking of doing the same on my 72 Targa with turbo tie rods because I do get similar kick / bump feedback when I'm in a turn and going over bumps.
Opinions, etc? TIA,
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 10-31-2008, 01:26 PM
Scott,
Those are all ERP components on that page,...
Bump steer kits such as the ERP one and Elephant Racing version are designed and intended for cars that are lowered beyond the normal range or have raised-spindle struts. Further, people who want the ability to fine-tune bump steer for optimal handling behavior need such products to make fine corrections on each side.
In these cases, rack spacer kits simply cannot make the required corrections to steering geometry that minimize toe changes through 2 inches of bump & 2 inches of droop travel.
Your car's ride height will determine what corrective measures will be needed to minimize bump steer.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-31-2008, 11:14 PM
