Comments on my 915 case?
Good day!
A short while ago, I posted and received some helpful comments on the condition of my '72 915 5-speed tranny synchros and dog teeth. I received this tranny as part of a project car; although previous owner claimed it was a driver before he tore the car apart, I was not able to experience how well (or poorly) the tranny shifted/worked.
Since then, I have continued to disassemble the tranny including removal of the ring/pinion gear for general inspection, as well as replace the mainshaft seal from the inside of the unit. A few things caught my attention that I'm hoping for some opinions on...
First, the mainshaft bearing in the main case has a retaining clip holding it in... this clip seems to have a bulge on one side - didn't seem normal, comments? As well, seems to be some scoring around this area; not as concerned, but comments appreciated on this area. Pls see pic that follows:
Second question is what seems to be a gash in the tranny housing from who knows what - perhaps a ring/pinion gear that got out of whack? Current gearset is in fine shape with no scoring, etc... Just wondering if I should be concerned with the condition of this housing, or if it's fine to use in current shape. Your thoughts and comments greatly appreciated.
Thank you,
Pat
'58 356
'69 911T sunroof coupe
'72 911RS replica project
'95 Carrera4 cab
Old 11-07-2008, 09:39 PM
AutoBahned
RWebb's Avatar
interesting - here is your Saturday bump
Old 11-08-2008, 12:18 PM
