Painting Exhaust HE's
I know the muffler can be painted with high heat paint. What about the stock heat exchangers/headers on an early car? Are they difficult to remove? The engine was rebuilt 3 years ago.
1972 911T/S MFI Survivor
Old 11-13-2008, 11:09 AM
Band.
If the engine was rebuilt 3 years ago it shouldn't be hard to get the HEs off.
As far as paint goes, IMO it's LOTS of hassle, little benefit. Even the best high heat paint doesn't last very long, and the first time you hit your painted HEs with some degreaser or something to get at an oil drip, it'll destroy your paint job, that only lasted a month anyway. And you need to ask yourself the question WHO is ever going to see it?
When I have the chance again I will just media blast my HEs and leave 'em be.
Of course, SSIs are the glamour choice
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-13-2008, 11:16 AM
Thanks for the info. Mine function great but look a pretty sad from the rear corners.
Old 11-13-2008, 11:17 AM
Crotchety Old Bastard
RarlyL8's Avatar
The key is cleanliness and being thorough. My stock 930 exhaust was sand blased and then coated with paint specifically developed for exhaust systems.
This was done 10 years ago. The first picture is when they were finished and the second picture is current. They still look pretty good. The color has gone grey but nothing has flaked off.
Do not remember the name brand of the paint. I am sure there is even better stuff on the market today.
3 yr old exchangers should not be difficult to remove.
Old 11-13-2008, 11:26 AM
I had my factory HEs and muffler powder coated in '98. they still look fine although not pristine. Surface prep is the key. Degrease and sandblast. However, after 39 years, they might be getting thinner (also lighter ) from the inside.
If new, I'd vote for ceramic coating, inside and outside.
Sherwood
Old 11-13-2008, 12:00 PM
AutoBahned
RWebb's Avatar
for a cheap 'n easy 'fix'...
slather on that Eastwood coating - bet it'll last a good long while
Old 11-13-2008, 01:25 PM
Band.
Sherwood
Really? I didn't know powdercoat could handle that kind of heat. Did you experience any downside to the powdercoating?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
Old 11-13-2008, 02:40 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Agreed clean clean clean is the key to the paint sticking good. I did my factory exchangers about 5 years ago with POR-15 high temp stuff. It's still sticking very well. Lots of high heat cycling from track days hasn't peeled it off yet.
Kevin L
'86 Carrera "Larry"
Old 11-13-2008, 02:48 PM
rfuerst911sc's Avatar
Professional ceramic coating.
Old 11-13-2008, 03:21 PM
AutoBahned
RWebb's Avatar
Gogar -- ceramic coating # powdercoating
Old 11-13-2008, 03:30 PM
Maybe not the typical powder coating material. No down sides.
Sherwood
Old 11-13-2008, 03:45 PM
