Blade
Need Help - door won't lock with key
OK, I re-keyed my drivers door lock so that I now only have one key. I also put on a new/used door handle because the finish was missing on the existing one (PO had spray painted poorly).
When I install the door handle it will open the door and if I flip the door catch manually and then manually push the lock lever inside the door, the door locks and when I turn the key it will unlock. The problem is the "PIN" that turns with the key has nothing to "pull" the lever on the inside of the door over to the "lock" position. So I can't lock my door from the outside with the key. What am I missing? I've check in the bottom of the door for a missing piece that might have slipped off the "lock lever" that the pin pushes on when you turn it but didn't see anything.
Help please.
1989 911 Carrera targa.
Thanks,
Blade
Blade
89 3.2 Targa
Old 11-14-2008, 04:08 PM
Blade
Never mind, I just figured it out. The electric lock locks the doors with the micro switch. I didn't have the battery hooked up because all the wires from the electric window switches were loose.
Problem solved
Blade
Blade
89 3.2 Targa
Old 11-14-2008, 05:30 PM
Czar of C.R.A.P.
dfink's Avatar
Dang it why can't I solve my problems that way.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 11-14-2008, 05:34 PM
