frankc's Avatar
Adding a Knock Sensor
I am planning on using the Electromotive XDi2 for the electronic ignition project on my 2.7, and given that this unit contains an input for a knock sensor, I wondered if anyone has tried adding a knock sensor to a pre-Motronic 911 motor. Would I gain much by advancing the timing a bit more and having a knock sensor back things off when necessary? My setup is Webers, SSIs and Mahle 2.7 RS P&C (meaning I am only at 8.5:1 CR). If yes, where and how should the sensor be mounted? Where is it mounted on the 3.2 motor?
I did some searching here but did not come up with anything.
thanks for any insight or advice,
Frank
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-15-2008, 08:35 PM
efhughes3's Avatar
I think it's a tough addition since air-cooled 911 motors are pretty noisy and it's tough for the sensors to discern what a knock is. I'm no expert, however. I'd call Clewett Eng and ask them, they know these systems and 911's.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-15-2008, 09:40 PM
frankc's Avatar
My bad - I thought the 3.2 Motronic motors had a knock sensor, but after a little more research I discovered that the sensors weren't introduced until the 3.6/964. But since these motors were still air cooled, their must be a way make this work.
I will be purchasing many of my direct fire parts from Clewett, so I will ask them about it.
Frank
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-16-2008, 08:07 AM
I would rather be driving
jpnovak's Avatar
Frank,
You can add a knock sensor. Yes a 911 motor is pretty noisy but the frequency range of detonation is different than that of the valve train. The base of the CIS throttle linkage plate stud seems to be an acceptable location. This is at the cylinder/case intersection for #3.
There are a few options but if you are going to a Clewett system use theirs for ease of installation.
Old 11-16-2008, 08:41 AM
frankc's Avatar
Jamie,
Thanks for info. I was thinking that the sensor would have to be mounted closer to the head for some reason. If it can be mounted in the location you mention, that would be great. I may have removed that stud when I put the Webers on, but a bolt will certainly do.
I figured a high compression setup would benefit most from a knock sensor, but I'll see what Clewett has to say.
Frank
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-16-2008, 11:37 AM
jpnovak's Avatar
The base of the cylinder and/or case is a good area to mount the sensor. the shockwave from detonation is transmitted down through the piston, rod and into the crank where it can be detected on the case web.
Old 11-16-2008, 01:45 PM
Czar of C.R.A.P.
dfink's Avatar
Have just installed TEC3r and it was suggested by Richard Clewett not to use a knock sensor. This is on a 3.2 rebore to 3.4 with 10.5:1 JEs
Said the engines are very noisy. The TEC3r also has an input for knock. It might be something I give a try sometime but hate to push the engine that close to the limit.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 11-16-2008, 02:32 PM
frankc's Avatar
Originally Posted by dfink View Post
...it was suggested by Richard Clewett not to use a knock sensor.
Hmmm, not what I wanted to hear. I'll have to ask Clewett what is different about the 3.6 setup to allow the knock sensors to work on that motor.
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 11-16-2008, 04:17 PM
