-   -   Quick question - Remove windshield to get the dash out? (http://forums.pelicanparts.com/porsche-911-technical-forum/441616-quick-question-remove-windshield-get-dash-out.html)
911SCcdn 11-16-2008 01:51 PM
I have some cracks in my 71T dash and I looking to do a DIY job to repair.
Does the windshield need to be removed to get it out?
Thanks in advance.
Andy
RWebb 11-16-2008 02:00 PM
yup
equality72521 11-16-2008 06:04 PM
Originally Posted by RWebb (Post 4307120)
yup
yup 2
robmog 11-16-2008 06:15 PM
si
RWebb 11-16-2008 11:03 PM
I'll see your si, and raise you a oui.
pwd72s 11-16-2008 11:48 PM
What? No ja?
RWebb 11-17-2008 12:02 AM
odd, isn't it....
robmog 11-17-2008 04:20 AM
no ja, da
Porsche_monkey 11-17-2008 05:34 AM
Not an easy job. Why are you doing it, crack repair?
911SCcdn 11-17-2008 06:45 AM
yes, I would like to repair a few cracks on the top.
The car is a track car, so I am not overly concerned. I just do not want to go through removing the windshield.
I read up on your experience and was thinking of trying a variation of it.
Andy
carsngolf 11-17-2008 07:58 AM
http://forums.pelicanparts.com/uploa...1226937441.jpg
The only dashboard that can be removed without taking out the windshield that I know of is the '65-'66 with "buttons". The buttons are plastic covers which stick on the face of the mounting screws.
Rusty Heap 11-17-2008 10:08 AM
Okay, so my question is......once the windshield is out, (my 1982 911SC) then my bentley manual states to take the 5 scews along the forward edge of the dash by the defrosters out, yup, did that, then Bentley says "take 7 nuts off the back side to remove the dash." (they don't show diagram or arrows/pictures"
Do you have to gut all your henting/ventilation gear to access these 7 nuts? Are they on the "Bottom side, of the flat mounted top dash"? or more on the vertical fire wall where the dash gauges are mounted?
I'm lost at this step, can't find the nuts, and its driving me nuts.
thanks for any tips.
rb2100 11-17-2008 06:32 PM
I'm guessing that its referencing the nuts that you access from the trunk area. I can't recall 7 of them though. One on each corner of the dash, one each on either side of the the dash vents and I think two in the area in between the vent and passenger nuts. Must be one more between the drivers side of the dash vent and the guage pod.
Some are a little fiddly to get at but not too bad. Reach towards the dash from the trunk and feel around. Start with the ones in the extreme drivers and passenger side corners to get an idea of where they are located.
1982911SCTarga 11-17-2008 06:53 PM
Yes, for the most part, and yes. There are studs protruding from the bottom of the dash through the chassis with nuts on them. You might be able to get a couple of them through the gauges. The number of dash studs varied over the years, too, so keep that in mind if you think you've got them all and the dash still won't come out.
Brian
Rusty Heap 11-17-2008 06:57 PM
Well if I can get it out, I'll have a mint black dash cover for sale soon........car is dead and getting parted out.....thanks Rob and Brian for your help.......
kodioneill 11-17-2008 07:07 PM
give me first shot please
rattlsnak 11-19-2008 08:58 PM
OK what? Ive pulled many dash covers off without pulling the windshield on 72 and up cars.
(dont know about earlier ones because i personally have not done one.)
RWebb 11-19-2008 09:32 PM
dash covers? i.e. aftermarket things
or dashes?
rattlsnak 11-20-2008 10:16 AM
Dashes. Why would you have to remove the windshield? When i thought deeper about it, some of the ones I did already had the windshield out, but some didnt.
EarlyPorsche 11-20-2008 10:23 AM
My 66 without buttons can be removed with windshield in place. Not sure what to tell you!
