LinkBack | Thread Tools | Rate Thread |
I would rather be driving
930 caliper rebuild -alternative sources and cross-reference parts?
I have a set of 930 calipers (917 style) that I am slowly bringing back from the dead. I managed to free the stuck pistons but fried the wiper seals and dust boots (what was left) with the torch. Of course, the plan was to use new seals.
Now a single caliper rebuild kit for a front 930 is approximately $85 from our host. Ouch. Thats a lot of money for 4 seals and 4 dust boots. Does anyone know? A pair or early M rear calipers has a 38mm piston. The front 930s have 4 38mm pistons. Are the seals and boots the same? Are they close enough to fit? This route would be $26/caliper. I suppose I should order up a set and see if they fit. HMM I might have a set of the shelf. Any way to avoid the $58 each for cross-over tubes? This getting really expensive - as usual. Thanks for entertaining my thoughts.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
the boots are not the same on the m calipers you still need the scraper rings even if the seals work...all brembos use the scrapers not boots
Sports Purpose 911 Driver
Hey buddy
Have you called VCI? They seem to be really good guys with good service. Maybe give them a call and see what they think. Good luck!
James Shira R Gruppe # 271 1972 911 Coupe 3.8 RS ‘nbr two’ 1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie' 1955 356 Pre A Coupe ‘old red’ 1956 356A Emory speedster build in progress |
Ever jump a Porsche?....
Jamie,
You should contact Zuffenhaus. I know they are making a 917 caliper now. In speaking with Keith, he said that their specs matched the factory so that they could also provide replacement parts for original calipers. He might only have newer speced parts and I'm not saying to go to him for parts and compete with Pelican. He definately can help you with some of your rebuild questions though. Give him a call/PM. eimkeith is his name on the BB.
Casey Road-rally, Targa Newfoundland junkie!!! 1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome! |
Thanks guys. The question is not about availability, its more of cost. Simple rubber parts should not be so expensive when injection molding is cheap. I guess its just economy of scale and the Porsche tax.
Yes, I am watching for the results of the Zuffenhaus brakes. HMM I owe Bob a call. Jamie
Jamie,
I rebuild and restore a lot of the 930 calipers for customers. Brother I feel your pain when it comes to the cost on rebuild parts. In the past I have bent my own cross over tubes from a piece of straight line. It takes some time to get the curves right but saves you about $50 per line. Also I have sourced the rear scraper seals at a much more affordable price than the Brembo ones. The front scraper seals are a very oddball size on the OD so I have not found those yet. As for the internal pressure seals I would suggest using the Brembo ones as they are about only $3 each. Here is a pic of the last set I did just to keep you motivated on the project. They came to me in very very nasty shape and had that crappy red "caliper paint" all over them. The paint had trapped moisture under it and led to some corrosion but they turned out pretty good in the end.
_____________________________ Clint Smith www.RebelRacingProducts.com 1970 911T ----> RGruppe RS/R (mexico blue) 1995 993 becoming an RS (gran prix white) |
sudo apt-get purge 930
I was just looking at the cost of doing this and nearly had an aneurysm when i saw the parts prices. I'll be watching this thread.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Can someone do me a favor and let me know the demensions of a 930 caliper? I'm trying to come up with a Wilwood solution that will still fit under my 15s.
Thanks a bunch.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
I can't find the pelican rebuild kit?
Is it the whole kit or are parts sold indivudally?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
yep, im slow in the head
oh, the next thing i had on my list to look into was this......... uff........ even calipers are un=cheap/costly to rebuild...?...... shucks.hahaha
![]() Subscribed. I would like this info also.
(the shotguns)
Did you check PMB Performance?
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I have #'s for individual parts if needed.
over $300 f&r
