a.k.a. G-man
Geronimo '74's Avatar
8X16 Fuchs in front
Is this possible?
I'm buying a set of 7 and 9 Fuchs wheels and I want to switch with the 7 and 8 I have now.
Can I put 8s up front? (regular carrera flares)
I don't want to use a lot of neg camber. It is not a track car.
thanks guys,
Old 11-20-2008, 07:03 AM
IROC's Avatar
I think the only Fuchs 8s that will work are the special offset 951 8" Fuchs. Regular 8s won't work.
You have the 8s now? Heck, bolt 'em on and see what happens.
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 11-20-2008, 07:12 AM
MBruns for President
JeremyD's Avatar
Is this possible?
thanks guys,
I have 8's and 9's - the 8's in the front are 951 version part number (951.362.117.00)
Old 11-20-2008, 07:29 AM
Bill Verburg's Avatar
Is this possible?
thanks guys,
No question about it, Use the 7 & 9 for a street car
the 944/951 8" Fuchs Jeremy mentioned can be used, but it's not a comfortable fit, especially w/ street alignmenst, the o/s is just a tad low @ ET23.3(same as the 7s)
To use an 8 on the front you will want ET25 - ET31
Bill Verburg
Old 11-20-2008, 07:59 AM
a.k.a. G-man
7 and 9 it is then.
Thanks guys
Old 11-20-2008, 08:15 AM
