What is the lug pattern for a 911
Hello,
I have searched the forum for this info but can't find it. I need to know what the 5 lug bolt pattern is for the 911's with trailing arms. Any help would be greatly appreciated.
1978 race car scca GT2 1998 C2S sold 1996 C4S sold 1973 911 T restored with 2.7 RS running gear 1970 911 E Project |
You need to sharpen your search skills
5 X 130mm
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Non Compos Mentis
And just so you know, no other manufacturer uses the 5x130 pattern. The wheels must be Porsche-specific.
5 x 130
Ed,
Thank you all for the information Ed what terms did you use in your search I tried 5 lug bolt pattern, 911 lug pattern, porsche bolt pattern, 911 hub pattern, etc.
porsche 5 bolt lug pattern wheel spacers
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
I love the search. I used the above recommendation and here's what I got:
"Sorry - no matches. Please try some different terms. The following words are either very common, too long, or too short and were not included in your search : 5 So, you can't use "5". How many people have you seen type "five"?? |
I used google.
Ah, brilliant!
Never thought of google for a pelican search. Good idea. |
I knew the answer, so I didn't have to search...but I think bolt pattern is the term I typically see used-that may provide results.
You can use a * as a wildcard to fill out the three character requirement, for at least one of the spaces. Such as H1* to look up anything on H1's.
