Question squirrely steering 1982 SC
Hello, I have an '82 SC and have a tire pressure situation/question. Since owning it for nearly a year, I didn't check pressure and she rode fine, like on rails. Was a little hard on the bumps, but thought that was just the nature of the beast.
Last week I decided to check the pressure and adjust the pressure according to spec (29 psi in front and 34 psi in rear). I came down to these levels from 39 psi all around. I was excited to see how nice of a ride I would have.
Problem: now the steering seems "squirrelly", I can feel the car oscillating back an forth all the time. Has anyone else had this situation, and any input on this would be appreciated.
thanks,
Bill
Old 11-20-2008, 07:57 AM
A couple of simple things first:
1. Check that your wheel nuts are all tight. This is more common than you may think.
2. Because you've reduced the pressure to spec., which is fine, and the size of the fronts/ rears are different, sometimes if you are on a somewhat rutted or ridged road, the car feels like it wants to track off course - mostly in the front because the fatter tires in the back are riding side to side, and up and down over the ruts causing you to try and compensate by oversteering. This is the road, not the car, and is normal. Try driving it on a straight, newly paved section of road and see if the car tracks straight. It should.
3. Align and balance.
4. Suspension and steering components - ball joints, steering rack, tie rods, tie rod ends, sway bar links, etc.
5. Real squirrels in the steering box
Best of luck!
Old 11-20-2008, 08:14 AM
AutoBahned
RWebb's Avatar
check your tire pressure first
however, I suspect you have a Red Squirrel infestation problem and they may not be just in the steering box...
a quick test is to see if your carr feels slower than normal.
In contrast, Grey Squirrels are real petrol-heads and love a quick burn. So if the car feels jerky like a teenage kid is burning out all the time, check for them.
They are so fast and unpredictable in cars that it is hard to get a good pic...
Both species are known to cause handling problems.
Old 11-20-2008, 10:54 AM
thanks,
Bill
Yes, it's all about alignment.
Soon as you take it in and have it done, the printout will tell you how far out of whack it was.
Cheers,
Joe
Old 11-20-2008, 11:18 AM
burgermeister's Avatar
I like the factory pressures (29/36) on mine. A Porsche shop that put new tires on adjusted them to 29/29, and car got notably more tail happy.
Check your camber settings. A digital angle finder ($20 Harbor Freight, $45 Home Depot) works well. Too much negative camber and it starts wandering.
Check your toe in the rear. Should be slight toe-in. Toe out in back makes the car more squirrely.
Could just be that the fronts were only contacting in the middle 1/2 due to overinflation, and now that the whole tire sits on the road you're getting more steering feedback.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 11-20-2008, 01:37 PM
So camber makes no sense to me. If it were camber, the high pressures would cause MORE wondering in my opinion.
Here is what I think.. your tires SUCK. The sidewalls are allowing the car to wonder at lower pressures and your car is tight as a drum.
Age and brand, model of tires? Size?
JP
'76 911s Ice Green Metallic bone stock
Old 11-21-2008, 05:13 AM
thanks for all the input. i'll report back with brand of tire, condition, age. I also want to add more air and see if this improves as I head back up towards 39 PSI.
I am hoping and thinking my car is tight as a drum. I know the previous owners
"tracked" the car
Old 11-21-2008, 05:30 AM
"tracked" the car
Also.. I just changed my ride height and it seems to have solved this SAME problem.. Maybe the tire pressure changes screwed up your ride height. Check the floor to bottom of fender wells. You should have 1/2" MORE height in the front due to the deeper fender well in the front.. if its not than you are heavy wherever its higher than 1/2".
In my case I has more weight on the front than needed but it still wondered.. go figure.
JP
Old 11-21-2008, 05:36 AM
kodioneill's Avatar
how many miles did you drive with the pressures that high? overinflated tires will wear the center of the tire tread area. the outer edges will not wear as much causing uneven tread wear. a new set of tires may be needed.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 11-21-2008, 07:09 AM
thanks. no matter how this thing pans out, it looks like I be spending $ on tires
and/or service. maybe i'll fill back up near 39 psi and have it corrected this spring
it sounds like it is indeed tire wear/ride height issue
Old 11-21-2008, 08:03 AM
What? Are you afraid of a little cold? Pump em back up just to be SURE it does solve the problem.. let us know.. Im curious.
Also measure your floor to deepest part of the wheel well opening on each corner. You do not get to just stop like this.
JP
Old 11-21-2008, 02:17 PM
gtc gtc is offline
abides.
gtc's Avatar
I like mine at 3-4 psi over the recommended pressure, about 33/40 or so. But I have Toyo T1-Rs, which have a reputation for being a little squirrely.
Graham
1984 Carrera Targa
Old 11-21-2008, 04:51 PM
are you lowered much? You may need rack spacers
Old 11-21-2008, 06:27 PM
Yeah but would tire pressure bring this on? It is one of the reasons I asked for his ride height BUT lowering tire pressure will not change geometry, just ride height. However.. if he is below 24.5" he may need to correct for bump steer, agreed. I think he wussed out though.
JP
Old 11-22-2008, 06:43 AM
I'll collect some data, and report back to the group. Might be a good week or so. I appreciate all the input on this.
thanks,
Bill
Old 11-22-2008, 07:33 AM
Wouldnt change geometry but it would expose behaviors that may have been previously overlooked with the higher pressures. On the other hand. I drove around with 10 psi in one of my front tires a couple weeks ago for a week or two without really making much difference it just felt a bit mushy all around. I think its just a case of adjusting to a softer ride. I have a 1946 jeep with 35" tires. I can make it ride like a caddilac or a dump truck depending on tire pressure
Old 11-22-2008, 05:00 PM
SteveinTO's Avatar
1) String the car on a level floor & check rear toe adjustment. Bet you're not symmetrical there, or something is bent/broken.
2) Clearly, removing the squirrels from steering rack will help. Duh! Handle them like mice.
Old 11-22-2008, 11:35 PM
