krd krd is offline
krd's Avatar
suspension rebuild - what am i missing?
well, finally got the 911 up and disassembled. i am doing a suspension rebuild, here's what is on my list so far....
front:
1. turbo tie rods w/spacers
2. front struts
3. ball joints
4. camber strut brace
5. front sway bar bushings
6. front wheel bearings
7. front brake pads
rear:
1. rear shocks
2. rear sway bar brackets
3. rear sway bar bushings
4. rear drop links
5. c.v. boots (inner and outer)
6. rear wheel bearings
7. rear brake pads
8. emergency brake pads
what am i missing???
btw - my car is only driven in the summer months (no rain, no snow). it's a weekend cruiser.
1988 porsche 911 "CE" cabriolet
Old 11-24-2008, 01:32 PM
At the track = great day
ChkbookMechanic's Avatar
bump steer kit / steering rack spacer, torsion bars ?
Lane
2011 Volkswagen Jetta SportWagen TDI
Looking for another sports car..
Old 11-24-2008, 02:21 PM
barney911rs's Avatar
Sounds like just a freshen up, not an upgrade, so probably don't need bump steer and new torsion bars.
Front - I assume you mean just the front strut inserts not new struts. If you don't track the car, you probably don't need that camber brace either.
Rear - If by sway bar brackets, you mean the stronger ones, good. Not sure why you need new drop links. This a wear item on the newer cars??
What about brake caliper rebuild kits front and rear to freshen them up as well. News seals, etc.
John Snodgrass
1973 Porsche 911 "Barney" (race car for sale)
2008 Nissan Maxima - Daily Driver
1999 F350 Diesel Crew Cab - Tow Beast
1990 Airstream 36' Land Yacht - Home Away From Home
Old 11-24-2008, 02:30 PM
+ lurking - contributing
Inspect for wear and replace
Front: A-arm bushings
Rear: Control arm bushings
96 BMW M3 Coupe
89 951
08 Astra H
Peugeot moped
Old 11-24-2008, 02:57 PM
How would you check for wear on these? And when you say control arm are you also meaning the swing plate bushings? The reason I ask is I just elected to keep mine based on Waynes book.. I think it says that he does not recommend replacing unless they are cracked as nothing is as good as the original bushings there.
When I had mine all apart I played with the bushing on the control are or swing axle or whatever you call it.. the ones near the transmission.. I simply noted that while they were sort of stretchy, and pliable, they were connected and not broke.. is that a "pass"?
I'll do a search also on this but I thought Id ask if you dont mind (like you had a choice).
JP
'76 911s Ice Green Metallic bone stock
Old 11-24-2008, 03:53 PM
Your control arm bushings front and rear will be shot .The rubber deforms with age and weight to an oblong shape.If the front end knocks over bumps look carefully at the torsion bars for telltale grooves from metal contact(because of worn bushings)The bars can probably be reused but look at the groove and smooth it with emory at least. I have used Weltmeister poly up front(with grease fittings) and neatrix at back But have only put about 20000 mi on in last 4 years so can,t vouch for long term The ball joints may be passable but worth changing with anything over 75000 mi. The wheel bearings will probably be OKand reusable if they,ve been cleaned and repacked at least once in their life. Check brake hoses for cracks and look at any rubber parts such as fuel pump hoses while under the front end.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 11-24-2008, 03:57 PM
Max Sluiter
Flieger's Avatar
The rubber sags over time, allowing the torsion bars to ride on their housings. This results in squeaks and a harsh ride because the metal is grinding itself away and the bumps are transmitting energy right through the metal, not rubber.
This is especially common in the front. If you let this condition continue for much time, you will need new torsion bars.
Old 11-24-2008, 03:59 PM
Max Sluiter
Flieger's Avatar
Poly-Bronze bushings are best. They have much less friction than stock rubber, even when the rubber was new. This allows for freeer suspension travel. The ride harshness will be lessened. The ride stiffness is determined by the torsion bar spring rate.
Old 11-24-2008, 04:01 PM
