ShakinJoe's Avatar
THE WEIGHTS - RSA Panel vs CF Panel vs Stock Panel
Many of you have been following my weight loss thread titled "438 lbs gone in 5 days - My Build Story". (438 lbs gone in 5 days - My Build Story)
I have meticulously documented the weights removed from my '87 Carrera and I am now publishing them for those that want to know the facts. Enjoy!
The best thread that I have found for RSA door panel installation is included right here. It is titled "RSA Door Panel - How To" .
A special thanks has to go out to Bob at AppBiz and Phyllis at GT Racing. Phyllis supplied a CF door panel for weight purposes and trusted that I would return it. Bob at Appbiz whent WAY out of his way and helped with all kinds of interior stuff that will be posted shortly. Bob guided me via phone & email many times and it refreshing to see that people like Bob still like to work for a living! I cannot thank them enough!!
HERE WE GO!!! If you are wondering how much weight a RSA door panel will save you over the current 74-89 stock door panel; You will find the answer to be 12.33 lbs total. If you do not re-install the lock bezels you are looking at 12.47 lbs. What about a Carbon Fiber model offered by AppBiz and GT Racing?? The CF Panel with the Aluminum Handle and Aluminun Bezel for pull strap weighs in at 3.31 lbs vs the RSA at 3.59 lbs. Keep in mind the RSA panel has the stainless window bezels installed, so I would call them just about even. If you think the CF will save you weight....it will not. The CF choice is about taste and $$.
Now for the Data!!
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 11-30-2008, 10:04 AM
ShakinJoe's Avatar
Some before and After Pics
Old 11-30-2008, 10:06 AM
Send a message via AIM to Ag02M5
I am thinking that covering the manual lock mechanism isn't a great idea unless you have manual windows. Blow a fuse and you may be in there for awhile.
Maybe fashion some new pins for the top of the door with a head that you can pull up in an emergency.
WTB: 964/965 Turbo stuff...carbon fibre bits, Techart wheel parts, RS/lightweight flywheel, 993 EVO uprights, G50 gears or 6 sp., 964 RSR swaybars, custom droplinks and any other cool stuff, pm me! Also a nice medium build 327 Chevy engine.
Coming SOME DAY...1991 3.3 turbo, Tahoe Blue Metallic with some mods
Old 11-30-2008, 11:02 AM
AutoBahned
RWebb's Avatar
thanks Joe
this is using the "scale that is used to weigh refrigerant very precisely" (from your first thread)??
do you know the stated accuracy of the scale? if not, what is the max. wt. it will measure?
Old 11-30-2008, 11:09 AM
ShakinJoe's Avatar
I have electric locks, and I think I can still open door with key even if fuse is blown...I think! Good point though.
Old 11-30-2008, 11:28 AM
ShakinJoe's Avatar
thanks Joe
No problem Webb,
The scale model is Inficon WeyTek and it is the same scale I have used in the weight loss thread and on every item.
Max Weight is 220 lbs
Accuracy is 0.25 oz
Old 11-30-2008, 11:36 AM
Joe, what was your total weight loss attributed to your work on the interior and going to two race buckets and lt wt interior?
I have always guessed about 100 lbs total there.
Old 11-30-2008, 01:01 PM
Better yet how about by category:
Interior.
Bumpers.
Rear duck tail.
A/C
Battery
Exhaust
Boot contents (spare, tools, jack...)
Other??
Old 11-30-2008, 01:06 PM
ShakinJoe's Avatar
911st
My breakdown will be posted on my wieght thread. I am cleaning it up right now and might have it done tonight. I will let you know what I added back in, but the post spreadsheet will only show weight out. Currently I am at 522 lbs Out and 133 lbs back in.
My classifications are as follows:
Body
Bumper Front
Bumper Rear
HVAC-A/C
HVAC-Heat/Vent
Interior - Door Panel
Interior - Insulation
Interior
Other - Mechanical
Old 11-30-2008, 01:14 PM
tw porsche
Kool stuf, very informative. My 82SC is down to 2394lbs with 37%front and 63%rear with 1/2 tank and no driver. I wish to know what you do and the weight savings on the rear lid. If anyone would wish to chime in to me about the ratio's and how much off the rear I can save let me know, thanks Tom
Old 11-30-2008, 01:53 PM
ShakinJoe's Avatar
Go to this thread.
Old 11-30-2008, 02:01 PM
Bob at appbiz here
Joe I suggest you purchase some plastic 70's VW lock plungers for the doors, this will enable you to unlock the car from the inside with a negligable weight increase.
Bob
Robert Breshears
bob@appbiz.com
310-834-3600
Owner Appled Business Concepts
Old 12-19-2008, 09:34 AM
ShakinJoe's Avatar
Originally Posted by appbiz View Post
Bob at appbiz here
Bob
Thanks again Bob!! I was hoping someone would have a solution.
The post on your rear mat is on the way. I have had some computer problems.
Old 12-22-2008, 08:14 PM
Bob at appbiz here
Bob
Let me know if anyone finds an actual part. Especially with a way to light up like the factory pins, which I am not sure how to activate.
Also, i would need a carbon panel with no round cutout.
Cheers.
RT
Old 12-22-2008, 08:18 PM
ShakinJoe's Avatar
Ask Bob at Appbiz about the CF panel.
Old 12-22-2008, 08:21 PM
AutoBahned
RWebb's Avatar
944 door lock - ah - thingies - light up with red LEDs - I don't have a pic -- a guy in BC has that car now
so if he sees your thread and is motivated he might be able to post a pic
Old 12-22-2008, 08:53 PM
http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_INTpnl_pg1.htm
Two at the bottom. Anyone up to try?
RT
Old 12-22-2008, 09:04 PM
Send a message via AIM to NoLift911
Looks good - there is also a number of "bits" inside the door that can be removed, clips, tabs and "block" attachment points that would save you maybe another .5 lbs per door - not sure if you noiced them in there or not.
As far as the attachment points - you can attach the entire panel with no exterior clips - it can all be done from the inside with the clips that Bob sells at Appbiz, panel looks much cleaner.
Also one round foam bezel takes care of the door lock problem - vs the foam
strips.
Anyway good job and good documentation.
Jeff
Old 12-23-2008, 08:18 AM
AutoBahned
RWebb's Avatar
take out the safety beam too -- it weighs a lot...
Old 12-23-2008, 09:20 PM
Jeff Alton's Avatar
Would you take the bar out with out a cage?
Did the early doors have the bar? If not, anyone know what year they came into production?
Cheers
www.turn3autosport.com
Old 12-24-2008, 08:17 AM
Tags
door , panel , rsa , weight
